1j not starting issue
Old 01-11-11, 11:08 PM
Superjatt
Superjatt's Avatar
Default 1j not starting issue
Wassup yall
so my 1j is in and its not starting.
When you turn the key you hear the injector and clicking from the starter. fuel pump is working.
ANy help?
Old 01-12-11, 04:34 AM
99SC42
99SC42's Avatar
was the Neutral Safety Switch Bypass done?
Old 01-12-11, 04:53 AM
stockhatch
stockhatch's Avatar
So the starter clicks but doesn't turn the engine over? Sounds like a bad starter, bad connection at the starter, faulty ground, or a weak battery.
Old 01-13-11, 07:58 PM
StiCk3
StiCk3's Avatar
weak batt is the first place i'd start
Old 01-13-11, 09:28 PM
Superjatt
Superjatt's Avatar
KK, update, i got the motor to start but i had to run a wire from the starter, I tried to look at biggus switch thing but i dont get it.
Old 01-13-11, 09:57 PM
Guest
Guest
Posts: n/a
i did the same thing. ran a wire from the starter to the wire under the dash. just keep looking at biggu's pics and directions all you do is splice a wire under the dash that gives power when you turn the key to the ON ENGINE START and its gives power to the other end of the wire that turns the starter on.
make sure you spice/t into the right wire. i forget what wire it is sorry.
Old 01-14-11, 05:28 AM
99SC42
99SC42's Avatar
That's the neutral safety switch, you can even do it at the plug that connect to the trans, just jump 2 wire together and whenever you put you car in reverse the R light will come on dash.
TACORICAN
01-24-16 11:20 AM
1jiggaSc3
SC- 1st Gen (1992-2000)
08-12-15 08:33 AM
geekhou05
07-14-15 06:15 AM
SlickChris
10-21-11 02:48 PM
Quick Reply: 1j not starting issue
