Last nites Seafoam experience on my 1JZ
I wouldn't call it sludge. More so just thick black oil. The petroleum in the seafoam takes all the buildup from inside the engine and loosens it up which is why you should change the oil within 100 miles of adding it.
I've never seafoamed a "modern" car. What are the effects, if any on the cats? You would think it would load them up pretty good. Especially if you did it with the engine cold and the cats not lit yet.
Putting it in the fuel tank cleans out your filter and injectors. Putting it in the oil cleans up sludge and such that have built up over the years and requires only a half can and changing the oil after a few days or 100 miles or less. Putting it in the combustion chamber cleans the runners, valves, and pistons but runs a slight risk of fouling plugs(never had it happen to me). The first 2 are simple and the combustion chamber isn't hard either.
If you still have the GE intake pull the large vacuum line from the valve cover side that goes to the intake and attach a funnel to pour the seafoam in. Pour about half a can in slowly with the engine running then kill the engine and let it sit for awhile to penetrate the old carbon buildup. After sitting start the car and let it sit for about 10min then take off up the road WOT to burn everything which usually only takes a mile or less and you're good to go.
taking in half the can thru the intake slowly then dump in 2nd half to stall Let it sit for ten minute Then blow the carbon out. I run Iridium plogs so the do not foul easily. Change the oil and you are done.
I've asked a couple mechanics about it. They were all cautious about it saying that stuff as toxic as seafom is really bad for anything rubber in the car, like engine seals and such. So you might not see any adverse effects for a while, but those rubber components will deteriorate much quicker. Any truth to this? Or is seafom made to be rubber friendly?
As curious as I am about this, I think I'm going to stay away from it, and maybe only try it on beater cars..
