Help with differentials..
i just got my sc. and ive messed around with a lot of welded diff 240's from friends. .. which would be the best road to take with diff for drifting?. what type of lsd. . id rather not weld them because id rather do things the right way. anyone who drifts. input would be appreciated.
welcome to CL
https://www.clublexus.com/forums/search.php
https://www.clublexus.com/forums/per...cheap-lsd.html
https://www.clublexus.com/forums/per...0-pumpkin.html
the main ones are the Auto TT diff from a supra, the Trd diff, or the Kaaz diff.
depending on what drifting and how many ways you want it to lock, those should cover you.
hmm. my friends told me to put a cusco 2 way lsd in it.. but they also said until i get it weld the diff's.. what do you think? i have a 92 sc400 thats gonna undergo the w58 manual swap in about 2-4 weeks then im gonna work on getting it "drift ready"
Any 2 way diff would be the way to go for any type of drift car. I have had plenty of built 240's and I still do. All of them have the 2 way and its awesome but if I had an input about what diff you should use then I would say go with either the TRD or ATS Carbonetics 2 ways. And yes 2 ways are noisy rearends. But if you are on a budget and this is your track car then a welded diff would be fine I just couldnt recommend it for dailying though.
No need to spend a ton of money on a diff.
This is what I do and highly recommend it, if you want to save money.
Weld your stock diff. It'll cost you around 60 bucks and it's RESPONSIVE, obviously, it's welded haha.
Find a second drift for daily driving. I found myself a Torsen out of an auto Supra for 80 bucks. When I go drifting, I just swap out my diffs. Doesn't take more than an hour. Trust me, you'll get used to it. Then swap them back for when you're going to daily drive.
I just think spending a thousand bucks on a diff is ridiculous. I know a professional D1 drifter, Forrest Want, and he uses a welded in his personal drift car. I know you said, "I'd rather do things the right way", but what's wrong about welding your diff?
