1jzgte on sc400..
Old 01-23-11, 12:21 PM
mbagang
mbagang's Avatar
Default 1jzgte on sc400..
worth it? .. i want my sc400 to be manual turbo'd. but i figured since they didnt mass produce many turbo manifolds for the 1uzfe itd be a pain. and manual swapping a motor that wasnt made for it might be also..
so any input would be appreciated. should i just do the motor swap?
what would prices range from for the motor swap anyway. just as an estimate? i found a jdm 1jzgte for around $2500 bucks. what else would be needed to make this happen? . .thanks!(:
Old 01-23-11, 12:52 PM
QwkSC
QwkSC's Avatar
Please start using the Search function. Most of the questions you have been asking have been asked before if not pursued and completed.
https://www.clublexus.com/forums/sea...archid=6027350
Old 01-23-11, 02:02 PM
iridebmx
iridebmx's Avatar
theres just a few extras to do it into a sc400 than a sc300.
resistor jump on your cluster, motor mounts, moving various parts around in the engine bay, and like a couple more things i cant remember.
is say if your thinking about dropping $2500 into your sc400 go w58 5-speed! its not as common and you get the fun factor of a 5-speed v8.
http://www.quantum-auto.com/store/
http://store.driftmotion.com/static/c-lexusscgs.php
those two sites got just about everything you need to get it done except driveshaft and tranny
Old 01-23-11, 02:26 PM
MrBrock
MrBrock's Avatar
Two other options for you to consider.
Supercharge the V8
http://www.bulletcars.com/supercharg...er-system.html
or 2UZ swap
http://www.lextreme.com/Lexus-4.7L-Tundra-swap.html
or you could do both. Either option would be easier than going to a 1jz. They're both in the $5k+ range, but swapping to the 1jz will most likely end up costing you well over that. Something to think about
Old 01-23-11, 07:13 PM
mbagang
mbagang's Avatar
Thank you(: but I decided I may just sell my sc400 and add money and buy a manual sc300 whenever I can come across one. I feel like it would suit me better since I'm looking into getting this car "drift ready" but definitely thanks for the suggestion
702SC400
23
06-11-09 11:24 AM
tuninghaus
07-06-08 10:03 AM
wbinc11m
07-14-05 05:44 AM
supathug
SC- 1st Gen (1992-2000)
04-22-03 07:29 AM
chris allen
02-21-03 07:10 AM
Quick Reply: 1jzgte on sc400..
