Drive-Shaft Help
Old 01-24-11, 02:48 PM
SC51
SC51's Avatar
Default Drive-Shaft Help
I'm trying to remove the carrier bearing on the drive shaft, I took the 24mm nut off along with cap and washer. Doesn't seem to want to come off, I hammered on it a little but it doesn't slide off.
Is there a trick or is it pressed on there?
Old 01-24-11, 04:12 PM
99SC42
99SC42's Avatar
No it should come right off, spray some rust penetrant and just wiggle it.
How is the tranny coming along?
Old 01-24-11, 06:35 PM
SC51
SC51's Avatar
Ehh you were right but i was hammering a little on the back side, bearings seem funky now... maybe I'll just swap it from the sc400 DS when time comes.
Anyway its commin slowly just ordering all the parts and install should be some time this month
deviategs
GS - 1st Gen (1993-1997)
10-19-18 01:28 PM
Z3RK
03-23-15 03:25 PM
havok123
09-17-07 09:46 PM
TurboSCLex
01-27-04 03:34 PM
Quick Reply: Drive-Shaft Help
