HELP! Running Pig ritch at idle and Lean at boost???
Old 01-25-11, 06:38 AM
1jzlover
1jzlover's Avatar
Default HELP! Running Pig ritch at idle and Lean at boost???
i just finish doing my 2jz swap and its running super ritch at idle 10.0 and when i go into boost it shoots up to 16.2, im not smashing on it just trying to see where im at with my wideband.
12 V modd and have a uprgraded walbro fuel pump
its a aristo 2jzgte stock twins on bpu upgrades
3 inch downpipe
fmic
STOCK PSI
Old 01-25-11, 02:32 PM
SC51
SC51's Avatar
Ehh it could be a lot of things. I know the JDM engines run rich when there first started. Do you have any codes? Check your O2 Sensor
Old 01-25-11, 02:58 PM
1jzlover
1jzlover's Avatar
Really so when they barely been swapped they run ritch at idle tho?
yea checked for codes and it's all clear..its a brand new 02 sensor too
Old 01-26-11, 06:40 AM
1jzlover
1jzlover's Avatar
Any suggestions??
Old 01-27-11, 12:46 PM
SC51
SC51's Avatar
^ya thats what ive read and mine does untill its warmed up it idles/runs perfect. Your base fuel pressure might be too low at idle causing the ecu to dump more fuel. Top end wise tho it will be lean. Again thats just fuel pressure related. Whats yours at?
Old 01-28-11, 06:46 AM
1jzlover
1jzlover's Avatar
hmmm ill check that out today after work
thanks
Old 01-28-11, 10:42 AM
Luv2xl
Luv2xl's Avatar
do you have a piggy back?
Old 01-28-11, 07:49 PM
1jzlover
1jzlover's Avatar
No Piggy back,I just orderd a Fuel Pressure Gauge,so ill be waiting on that to see how it goes?
smiley954
23
03-07-14 08:26 AM
LexCafe
Performance
28
02-09-12 03:29 PM
stenot2low
15
06-24-11 07:35 PM
1jzlover
GS - 1st Gen (1993-1997)
02-19-11 10:49 AM
soarer19
06-13-10 08:33 PM
Quick Reply: HELP! Running Pig ritch at idle and Lean at boost???
