2jz-gte (550cc) injector on 1jz-gte
Hi,
I will buy the 550cc USDM injector... I want know what that I must change or add... I listened that i must add resistor box... which one?
I have OEM Toyota Soarer GT-T Fuel Pump (i have a real Soarer, not the SC300/400 swapped)
I have in stock the S-AFC II (temporarly) and my EBC..
Resistor Pack.
![Name: Picture.jpg
Size: 96.6 KB](https://www.clublexus.com/forums/attachments/performance-and-maintenance/435252d1501368547-2jz-gte-550cc-injector-on-1jz-gte-picture.jpg)
MKIV Resistor Pack Wiring
![Name: howtowireresistorpack.jpg
Size: 23.5 KB](https://www.clublexus.com/forums/attachments/performance-and-maintenance/435253d1501368547-2jz-gte-550cc-injector-on-1jz-gte-howtowireresistorpack.jpg)
Use information at your own free will and taking the information I provided at your own risk. I am not responsible for any problems or damages that may occur
On my Aristo 2jzgte vvti the Engine Wire Harness 12 Volt Power to the Injector Clips is (Black / White)
STEPS
1•Cut all 12 Volt Power Wires to the Injector Clips.
2•Join the Black Wire from the (BLACK) wire from the MKIV Resistor Pack to the (Black / White) that goes to the Injector Clips.
3•Join Two of the 12 Volt Wires (Black / White) that was cut to the (WHITE) Power Wire of the MKIV Resistor Pack.
4•Cap off all of the (Black / White) 12 Volt Power that were Cut.
MKIV 550's Injector Clips Part Number 90980-11154
![](http://i729.photobucket.com/albums/ww295/Turbo819/2jzgte%20vvti%20Swap%20GT3582R/Picture3361.jpg)
440's Left & 550's Right.
![Name: Picture.jpg
STEPS
![Name: Picture312-1.jpg
Size: 107.0 KB](https://www.clublexus.com/forums/attachments/performance-and-maintenance/435254d1501368547-2jz-gte-550cc-injector-on-1jz-gte-picture312-1.jpg)
KiroLS (09-05-20)
ClemsonSC3
Performance & Maintenance
03-30-04 05:59 AM
