Battery light flash low beams shut off ABS light comes on? WTF?
So I made a mistake and let my girl drive my car. When she came home she asked me if my lights come on whenever they want, I respond no they should stay on. I go outside to check and find out when I rev my engine around 2k RPM the lights will shut off, So I have to drive with high beams. I went to Advance Auto Parts to check out my Battery,Starter,and Alternator. My battery needed to be replaced so I replaced that but it showed my Starter and Alternator was fine any idea what could be making this weird problem?
First video me reving the car you can notice the battery light flash on the bottom right.
View My Video
The second video is me driving down the street you can see the battery light flash and the ABS Light come on
View My Video
View My Video
View My Video
Alternator. That is definatly what it is.
I don't care what advanced says, it's your alternator. They cant really test them until they are off (I work there)...
Also-ill go ahead and guess its a 400 and that your power steering pump is leaking onto it and causing it to fail.
EDIT: I was wrong on the 400 part after listening to video haha
I mean, you can, but if you have already replaced the battery and it is still doing the same thing, thats pretty much the only thing it can be. Check your ground wire and make sure its making a good connection, but I highly doubt thats what it is. I say alternator 99.98% sure
