1jz alternator wire?
Old 02-03-11, 06:50 AM
Ace2jz
Ace2jz's Avatar
Default 1jz alternator wire?
I was replacing my alternator on my car today(1jz) I disconnected the wire from the back of the alternator and as I was taking out the alternator I see the wire I just disconnected drop to the floor and when I picked it up I notice at the end of the wire it look like it was cut an taped upi try looking on the harness an couldn't find where this would connect but does anybody has a clue to where it would go
Old 02-03-11, 07:08 AM
jcastaneda
jcastaneda's Avatar
I take it you are talking about the plug? There are 3 wires or so? A pic would help.
Old 02-03-11, 07:23 AM
Ace2jz
Ace2jz's Avatar
Yea the plug with the 3 wires I'm sorry I took a picture and was posting this on my phone on the way to autozone I'll get the pic up real soon
Old 02-03-11, 07:35 AM
jcastaneda
jcastaneda's Avatar
In the wiring harness there are three wires. I am not sure as to the colors but from left to right one is the IG, S, L. That is what they label them as. I know one is the ignition. and the is the one on the left...not sure about what the S and L stand for.
Old 02-03-11, 07:41 AM
jcastaneda
jcastaneda's Avatar
To determine the iginition wire (IG). You can check that you have the right wire by sticking the voltmeter prong into harness and determine that voltage is present only when the key is in the "run" poistion but not in the "accessory" position.
Old 02-03-11, 08:02 AM
Ace2jz
Ace2jz's Avatar
thats exactly how i found it....
Old 02-03-11, 08:40 AM
jcastaneda
jcastaneda's Avatar
How many wires are in the wiring harnes currently? Those alternators should have 3 wires going into the plug....you can't tell if the wires as twisted to another one or any other signs?
tyncobb
07-05-17 07:29 AM
JesLet
11-05-15 08:16 AM
decypher
04-23-11 10:20 PM
bmarsh757
GS - 1st Gen (1993-1997)
02-19-11 10:35 AM
Quick Reply: 1jz alternator wire?
