sc400 manual swap with mk3 trany help plz!
Old 02-06-11, 06:56 PM
xxtoobsxx
xxtoobsxx's Avatar
Hey red i keep checking your site out for the r154 swap parts and its not listed in the store! I literally need a clutch and flywheel, maybe your adapter place too not sure since i have one
Old 02-06-11, 08:02 PM
RedPhoenix
RedPhoenix's Avatar
We have a 2nd revision of our adapter that will be on the site... has a few other things the first one didnt have. But its all the same... PM'd.
Old 03-09-11, 10:55 PM
1998sc300
1998sc300's Avatar
i want to do an auto to manual swap on my 98 sc300 but im worried it will cost more than my car is even worth
Old 05-15-11, 03:12 PM
Meanshyguy
Meanshyguy's Avatar
^x2, but on my 93 SC400 that's why I'm selling the R154.
Old 06-01-11, 04:33 PM
JakeBreyck
JakeBreyck's Avatar
The Quantum R154 Kit is up on their website now. so now there is an easy R154 and W58 solution.
Old 03-03-12, 01:28 AM
EckzLexus
EckzLexus's Avatar
Im about to do my '95 with R154. I bought my internal parts from Driftmotion, my adapter and clutch/flywheel from Quantum-Auto (thanks Jake), found a nice r154 from a USDM 91 Supra Turbo, which I am rebuilding with all Marlin Crawler parts, and a master rebuild kit from Driftmotion. I also got new stronger poly diff bushings. I am also going to get Driftmotion's aluminum 1-piece driveshaft once I put it all in and measure it.
I was originally going for the w58, but opted to go r154 for my next planned mod. Im going to Lextreme route by swapping in a 2uz block/crank, 1uz connecting rods, ARP bolts/studs, custom Ross pistons, supra injectors, and Stage 1 cams. The only thing that Im having trouble with is getting the right engine mounts. I dont want to have to make my own, but it might come down to that if I cant get ahold of the Lextreme guy to order some.
Anyhow, stay tuned for pictures and more info on my swap...
Old 03-03-12, 01:34 AM
EckzLexus
EckzLexus's Avatar
Which reminds me... I have a Quartermaster #721-100 that is new in the box that I wont be using anymore. Holla if you want it. $200 shipped to the lower 48.
Old 03-25-15, 12:10 PM
bdoug724
bdoug724's Avatar
r154 front drive shaft, modify the tranny mount, clutch peddle assy and brake peddle assy, clutch resivoir, hydro TOB, Lines for TOB, Adapter plate or custom bellhousing. Then you need the quantum auto flywheel and clutch. then a bunch of misc items
I have everything but the clutch and flywheel. Where you located? Maybe I can help ya install it if your in San Diego area!
Hey do you still live in San Diego? I'm assembling everything i need for this swap and could use a knowledgeable hand when it comes time to install. the only other parts i need are a driveshaft and a few other small parts.
Doneve79
06-04-14 08:55 AM
96sc
SC400 / 300 Classifieds
12
02-20-12 02:43 AM
jroring
02-23-09 11:29 AM
mrshabo
05-19-06 08:55 PM
Quick Reply: sc400 manual swap with mk3 trany help plz!
