About to start my 1jzgte swap into sc300
Originally Posted by account2x
That is a misleading statement. It leads one to believe the 1JZ is a 700hp engine and the 2jz is 1000+.
Quite the contradiction since you are so stuck on 2jz headflow and half a liter of displacement increase.
Here is a stock internaled 1jz spitting out 7 bills.
http://www.youtube.com/watch?v=YmhyHwp8sp4
Here is a stock longblock 2jz doing 150 in the quarter.
3500lb car, 150mph in the quarter, carry the one..Hey! Stock 1000hp 2jz!
http://www.youtube.com/watch?v=QgapHDN_zMU
And another stock blocker, with stock headbolts!
http://www.youtube.com/watch?v=asqmqwuOwP0
What do you know!?
Less displacement and worse headflow means your turbo won't spool as fast. So if one was trying to optimize the powerband the 1JZ would have to run a smaller turbo than the 2jz. Therefore the 1jz would make less peak power than the 2jz.
That's a lot of big, smart sounding words even though there isn't one solid fact in any of your response.
Who wants to see Account2x's 2jz tattoo?
Who wants to see his 2jz car?
Who wants to see all these headflow charts he keeps referencing?
I do! I do!
Misleading? How? Bone stock, they are.
What do you know!?
Optimize? Therefore? Spool as fast as what?
I do! I do!
What do you know!?
I do! I do!
Do you ever have second thoughts?
You have to spend almost as much money on parts as your engine.
A Supra 2JZ bolts right up.
An Aristo 2JZ will bolt up if you swap over the GE mounting brackets and oil pan.
If you have to go through the trouble of extending the wires why not go one step further and repin them for the better engine?
The point i was trying to make earlier is about choosing the engine that fits what YOU want. it all depends on what you are looking for out of the car in the long run. I didn't intend to make this a 1JZ vs. 2JZ battle. I'll admit, head to head a 2JZ can romp on the 1JZ all day long. That doesn't mean a 1JZ is a ****ty engine. Just like any engine, it has its limits and it happens that the 2JZ can make the power where the 1JZ can't. However, a 1JZ can still be competitive with a lot of other cars out there.
If you want an engine with huge potential to be an all out monster and tear up a drag strip and then some, go with a 2JZ
If you want a good street warrior with decent power potential that's different than the rest of the pack, go with a 1JZ
i realize these are both generalizations of the two, but im trying to give the OP an idea at what he wants both out of the box and what he hopes for the future.
You will need....
- Water pump (2JZ works ok but you going to need to replace the timing belt)
- Timing belt (80s Izuzu Trooper with the 2.6L)
- Serp Belt (2JZ works ok)
- Thermostat (2JZ works)
- Front crank seal (2JZ works)
- Rear main seal (2JZ works, VERY good idea with the motor out)
- 1JZ gasket kit (don't have to replace all of them, but a very good idea to get at some with the engine out)
- Toyota FIPG (gasket maker)
- Supra TT power steering reservoir (if yours doesn't come with them)
- Supra TT radiator hoses (upper and lower)
- Custom heater core hoses (need to get creative with that...)
- engine mounts (mine were bad on my new engine and i couldn't reuse them off my old engine because they fell apart too.) Supra TT works BUT MAKE SURE THEY ARE THE SMALLER RUBBER TYPE!!! (part #: 12360-46111)
- spark plugs
- Toyota Red Coolant (2 gallons)
- 10W-30 oil and oil filters (you want to change out the oil very periodically for the first few miles)
- an extra $1000 for miscellaneous stuff like bolts, cleaners, oil hoses, etc.
it's been a while, if im missing anything let me know
For the fan i think you can re-use the fan and clutch off the old engine, but if all else fails get the 2JZ TT one.
- spark plugs
I am currently in between on which engine to chose. I figured the 1JZ would be cheaper and fit the power requirements I am looking for 400-500HP would be enough for me. BUT, it is a valid point that if I am going to have to spend another $1K on parts just for the 1JZ swap, I might as well go with the 2JZ swap..but then again, that $1K also includes gaskets and seals and the other stuff I would want to replace on either engine before I dropped it in. I guess I have time to mull it over until I get back stateside.
Now if you are going to swap in a 1JZ-GTE VVT-i then that might be a different story but even so I can't say the VVT-i makes up for the lower displacement and worse headflow.
God damn you.
YOUR Logic makes no sense Account2x.
You are saving tons of money going 1jz. If you find a clean one, you don't even have to touch the front of the engine.
$1200 done deal. You can't beat that with a baseball bat.
Saying the 2jz is better than the 1jz is like saying the 5.4 terminator is better than the 4.6.
At the end of the day the turbo is making the power, weather is comes in 500rpm eariler is up to the owner.
Seriously, you are so lame riding the 2jz **** so hard.
It doesn't matter which JZ engine you get.
You have never drivin a 500 hp car in your life, and you would kill yourself if you did.
So stop acting like you know the difference between 300hp and 1000hp.
Pages of your heresay bull****ting, along with your standby Google headflow chart that doesn't even say anything, are really staring to get annoying.
Lets see your 2jz smarta$$, and not some lame pedal swap that a drunk 4 year old can do.
Seriously.
If you love the 2jz so much, why don't you marry it?
Seriously.
Living life dangerously I see.
The engine spools the turbo dude.
whether.
The 2JZ is better than then the 1JZ.
whether.
You have never drivin a 500hp car.
You don't have a 2jz, so just stop.
Stop killing everyones thread with your bull shyte.
Just stop.
STOP.
570p.
stop.
And still no proof of your 2jz.
BYE.
Just stop.
STOP.
570p.
stop.
BYE.
LOL me too. I've really gotten my self into this....
account2x, i appreciate your passion for the 2JZ, but this isn't your car we're talking about here. Let the guy make up his own mind here. We are supposed to be here to give him insight on his decision, not turn this into a pissing contest.
^^ Exactly
I might as well address a few questions I have since I came into this thread. I talked to a few buddies back home who have a pretty good base of knowledge on all things Toyota and I was telling them about all the additional parts I would need (stuff I saw on the first page of this thread), they seem to disagree but it doesn't hurt to clearify.
I can't get to any ebay links because I am on a DoD internet connection, so I am not sure if those parts are necessary because the motor the OP ordered didn't come with them, or if it is because of the type of 1JZ he ordered, or what? I hate to be redundant but lets say I order a 1JZGTE VVTi, will I still need to source all of the extra 2JZ parts like the water pump, fan stuff, etc?
