Advice: Removing seperated Crank Pulley?
My crank pulley grenaded. I got a new one, had no trouble getting the 22mm crank bolt out, but now i cant get the pulley off. I cant use a puller because without the outer ring, there is nothing for the puller to grip....What is the solution here? Can you screw in bolts into the 2 holes on the pulley to push it off (like a brake drum)?
Thanks Guys!
Thanks Guys!
The Autozone stores here in Cali have a deal where you buy the puller (or any of the usually rented auto tools) and then they let you return it for a full refund (so it's technically not a rental) within 30 days or so. They used to loan them with a deposit, but they had to change to this method for some reason. Net result is that it's free though.
an impact gun works great to get the bolt off, but guys at work use them sparingly because there is a risk that the impact gun will kick out and can potentially damage the radiator when it does kick. If you go this route, make sure you remove the radiator so it doesn't damage it.
imDementeD
Performance & Maintenance
04-09-12 02:13 PM
speedemon
Northeast
06-23-09 10:22 AM
TMaxxTim
07-12-05 09:46 PM
