bad transmission?
bad transmission?
my car is a 94 SC300, 210xxx miles on the clock, auto, every time I engage R or D on the transmission the car wants to creep forward (or backward) but with a big clunk and not smooth at all.
I been thinking is the transmission going bad, I check the fluid is not that bad. but could use some change.
i been having this strange symptoms on my car, that got worse after I replace the steering rack bushings (if there was something left) with DAIZEN, and change the spark plugs.
anyway i don't think it have something to do with it but, as i said, it got worse after it.
I checked all the suspension components, everything looks in good shape but the LCA.
also noticed a low pitch ratcheting sound coming from the transmission area, it gets louder when i give it some gas.
don't think is that cause then the shifter would be shaking, right?
however I found this video, the noise coming from under the transmission is the same, http://www.theforcecollective.com/we...hirring_01.mov, but mine is a SC300.
Is the auto transmission the same in the 300/400?
and this is the tread i found https://www.clublexus.com/forums/per...ith-sound.html
I'm afraid the transmission quits. This is my DD and I don't own a gold mine, LOL. The shop charge big money for a transmission rebuild/replace.
I need HELP!!!
I need HELP!!!
