mk3 w58 int 93 sc300
Ok i got a crazy good deal on driveshaft w58 etc. I have searched many forums threads etc and its just random info all over the place even on here. I need to know from someone that knows what they are talking about. Will my mk3 supra w58 with the 1jz/2jz bellhousing and flywheel bolt into my 93 sc300. Will the shifter on it work. Thank you guys so much.
I just recently did this. Here's what I had to do in the end.
Put the 1JZ bellhousing on the mk3 tranny. I retained the original Mk3 tail housing (sc300 is close but won't fit) but put the sc300 mount on the Mk3 Tranny. IIRC, I used the shifter housing and rod (inside the tailhousing) from the sc300. I cut a little of the rubber and drilled holes in the tranny mount plate to match up with the holes in the tranny which allwed me to bolt the sc300 mount onto the mk3 tranny, and everything lines up. So currently I'm running with the mk3 w58. The speedo is a bit off though.
Just put your speed sensor into the mk3 trans. The gearing is different, so your speedo will be off. This can be fixed later with electronics. I'm still looking for a replacement Sc300 w58....sigh.
scfou
Performance & Maintenance
45
02-12-16 05:31 PM
