Single Turbo'ed 2JZGTE
Old 02-17-11, 12:29 AM
jdmjzz30
jdmjzz30's Avatar
Default Single Turbo'ed 2JZGTE
anyone here have a Single Turbo'ed JDM 2JZGTE Aristo motor, MAP Based?
What piggy back are you running or recommend. I am only referring to the JDM 2JZGTE Map based motor.
Old 02-17-11, 08:14 AM
Carfreak70
Carfreak70's Avatar
Many people here are running this setup.
I used E-manage blue and it worked great. I don't know why so many people hate on the E-manage blue. If someone knows how to tune it, it will turn out great. My car was always turn-key and never stopped running on me.
Old 02-19-11, 03:28 PM
RawkusX187
RawkusX187's Avatar
All jdm jz engines are map based, what hp you looking to make?
Old 02-19-11, 03:33 PM
stockhatch
stockhatch's Avatar
I have hear some good things about the emanage ultimate from jdm map based people. For conservative numbers(<500hp), it is what I will probably end up with. Some people have reported issues with it, but then again, you hear about issues with all piggybacks(and even some standalones) if you look hard enough.
Old 02-19-11, 08:20 PM
jdmjzz30
jdmjzz30's Avatar
I might give the emanage a try.
Old 02-21-11, 10:26 AM
trancuongv
trancuongv's Avatar
I have a 2JZGTE singled turbo with MAP based, I am running a SAFC 2. A lot of people from Supraforums run the SAFC 2 will great results.
Old 02-21-11, 06:23 PM
F4A22
F4A22's Avatar
Map-ecu here.On a basemap and it runs great.Doesnt affect timing and is laptop tuned which is much better than an s-afc.
Old 02-22-11, 04:45 AM
stockhatch
stockhatch's Avatar
Map-ECU 1 does not affect timing? How is that? So it doesn't manipulate map signal like safc? That sounds like a great alternative to me too then.
Old 02-22-11, 04:50 AM
99SC42
99SC42's Avatar
Map ecu is better than SAFC hands down.
But please make sure you have a tuner that can tune whatever ecu you decide to go with.
Old 02-23-11, 05:08 PM
tig_tech
tig_tech's Avatar
Yea I hate the SAFCs. All they basically do is trick the computer. Standalone or Chipped ftw.
Dai Kaiju
07-13-10 08:28 PM
RX7 RAGE
11-24-07 04:12 PM
brian lin
04-27-06 03:26 PM
SinisterSC
04-22-05 04:35 PM
Quick Reply: Single Turbo'ed 2JZGTE
