What plug is this for?
Old 02-21-11, 12:16 PM
joe diego
joe diego's Avatar
Default What plug is this for?
I dropped in a 1jz all by myself, but I can't figure what this cable plug is for. I'm hoping it's my speed sensor cable but I doubt it. I have yet to find my speed sensor cable as well.
Old 02-21-11, 12:33 PM
stockhatch
stockhatch's Avatar
Probably steering rack plug.
Old 02-21-11, 01:23 PM
joe diego
joe diego's Avatar
Hmmmm... I'll take a looksie
Old 02-21-11, 06:38 PM
meangreen1
meangreen1's Avatar
Being that the plug for the PS is on the other side, I would rule that one out. Maybe the front knock sensor. Up behind the alt.
Old 02-21-11, 06:56 PM
6SOARER
6SOARER's Avatar
Its for the steering rack. I had the same problem and someone pointed this out to me. You will need to extend it
Old 02-21-11, 07:30 PM
joe diego
joe diego's Avatar
If that's the case the inlet for the plug must be on the drivers side. Maybe that's why it's a little difficult to turn the wheel. I'll take a look tomorrow when I have light. Thanks.
Old 02-21-11, 07:53 PM
StiCk3
StiCk3's Avatar
+1 that is for the steering rack pressure switch. Allows for easier steering at lower speeds. Extend it to the other side of the car to the rack.
Old 02-21-11, 08:11 PM
Superjatt
Superjatt's Avatar
¿What color are the wires on that plug?
Old 02-21-11, 09:13 PM
joe diego
joe diego's Avatar
I think either green or yellow. Ill double check tomorrow. Why?
Old 02-21-11, 09:33 PM
6SOARER
6SOARER's Avatar
IIRC, they're both green but one was green with red tracer.
Old 02-22-11, 05:13 PM
meangreen1
meangreen1's Avatar
My power steering line had insulation around it. Strange that its on that side.
Old 02-22-11, 06:13 PM
stockhatch
stockhatch's Avatar
If you had a 1j swap, it should have been on the same side as the OPs due to the whole RHD thing...
canucklehe
11-20-13 10:52 AM
dondons_sc
SC- 1st Gen (1992-2000)
05-15-10 08:57 PM
meangreen1
11-04-09 10:11 PM
jdmjzz30
12-25-08 07:05 AM
Quick Reply: What plug is this for?
