W58 Transmission noise!!
After I installed my trans back in my swap, my W58 Tansmission started to make a chattering noise which it never made before. The noise gets louder when its cold and when I depress the clutch.
I topped the diff off with some Royal Purple, specs says it suppose to be 2.7qt but it got full after 1 3/4qt. What can it be? Is there a procedure filling up the diff?
First time I ever pulled a transmission so when I pulled it all apart I did not know what to look for or if anything was worn/time to be replaced.
Did you grease everything up? pilot bearing, input shaft, throwout bearing, fulcrum, shift fork
It's probably the TO bearing as it will slightly contact the pressure plate fingers and spin at idle, then as the clutch is depressed it'll seperate out to push the pressure plate fingers to clamp down
