What parts are all needed in order to change timing belt?
Old 08-23-02, 04:06 AM
Lexson
Lexson's Avatar
Question What parts are all needed in order to change timing belt?
Ah yes...another late night.
I am going to be changing the timing belt soon...but need to order the parts tomorrow. I know I need the belt....is that it? Do I need any tensioners or anything?
Also...now follow me here...what is the recommended service interval for changing the water pump and Tstat IF its not giving you any problems? Should it be changed every so many miles or only when it starts giving problems? I just had that and the thermostat done 2 weeks ago...(so yes I know you should always get it done with the timing belt, but obviously not in this case).....but just for my general knowledge, how often for those 2 parts?
GRACIAS AMIGOS. (1992 sc400 BTW)
Old 08-24-02, 12:07 PM
dganapol
dganapol's Avatar
Default Timing belt change
I just did this job. You will need the following:
1. Timing belt
2. Bearing #1
3. Bearing #2
4. Water pump (change as long as your in there)
5. Serpentine belt bearing
6. Serpentine tensioner bearing
7. Dist cap/rotor, and plugs (again as long as you are in there)
7. Helps to have the manual ($100)
Special tools:
1. Crankshaft holder to remove bolt (I made my own). I found all of the parts on the internet. Whole job cost me $300. Dealer quoted me $1700. Good luck.
david 95 SC400 Royal Jade
david _ganapol@rocketmail.com
Old 03-02-04, 09:58 PM
prjctSC300
prjctSC300's Avatar
i know this is an old thread, but my serpentine tensioner is making grinding noises and was searching to see if anyone had the same problem?? what should i change out when i change the tensioner out?? any seals, gaskets, or hard to get parts??? thanks
Old 03-03-04, 01:53 PM
mamurra2
mamurra2's Avatar
bearing # 6203, might as well replace the belt, 5 minute job...
use search next time
Old 05-25-04, 04:58 PM
kmn5
kmn5's Avatar
people are just changing out the bearingsin the tensioner instead of the whole assmeblies ???
Old 05-25-04, 09:23 PM
Hermosa
Hermosa's Avatar
Default Re: Timing belt change
1. Timing belt
2. Bearing #1
3. Bearing #2
While you are in there also do the following:
thermostat
cam and crank seals
Old 08-12-04, 03:40 PM
Project300
Project300's Avatar
The Lexus dealer only sells the whole tensioner as a unit. The bearing can't be replaced without changing out the whole tensioner. ($189 from my Lexus dealer) If anybody rebuilt their tensioner bearings I would like to hear about that.
There are some other (on topic) threads with more on this you can search.
Dallasguy1
GX - 1st Gen (2003-2009)
08-15-16 11:41 AM
Vito 06430
08-20-12 09:59 AM
Red Bully
08-16-08 10:21 PM
sorka
Maintenance
06-01-08 01:13 AM
harryliu
Performance
11-23-04 01:39 PM
Quick Reply: What parts are all needed in order to change timing belt?
