98+ 5speed swap BACKUP LIGHTS?
#48
Ok, so the shift lock ecu looks like it controls OD lockup, and then sends a signal to the ecu and cluster for either D, or both 3 and D depending on some variables. Do the 99s have an OD on/off switch like the early cars? It could be that that switch is unplugged which is confusing the 3/d lock ecu, or it is hiding under the console and is maybe set to "off"? I am wondering if jumping that "shift lock ecu" from pins 1 to 7 would trick it into thinking its in D.
#54
yeah i was thinking "if Park lights up, it's in park. why cant i crank it?"
something must be missed by hooking up the relay up at the IK/IJ plugs. this is probably why D doesn't light up when the other pin is connected (e-brake down).
i will move the relay down to the actual trans plug when i get home and see what happens.
#59
So I've just been kinda watching this thread (because I hope to do a 5-speed swap within the next 12 months) and I just want to thank you two ahead of time for all the invaluable info/diagrams you have posted. This thread seriously is an asset to the CL community. Great job guys! ...oh, and glad you got the Park/Drive/starting issue resolved!!
#60
The OBDI cars are super forgiving in that regard. The cruise is a one wire fix, and you won't get a CEL from removing the auto trans.
