What can I do to gain NA Power?
Old 03-09-11, 09:32 PM
boostinsc
boostinsc's Avatar
Cool What can I do to gain NA Power?
Well I have a 2jzge vvti motor completely stock but I want to bump up the hp other than intake,headers, exhaust all motor for now. Just so o can have a little bit of fun with the car. Then a manual 5spd conversion and that's all I have planned for now. Turbo later on.
Old 03-10-11, 03:25 AM
scmissle
scmissle's Avatar
Your going to spend more on bumping up naturally aspirated power than boosting it. However if you get to peak NA then boost it, you will not need as much boost to make power. If you still want to go this way there are some decent options. besides header, intake and exhaust, there is always cams, cam gears, raised compression (bad for boost unless E-85 conversion is in the mix) Intake manifold and 75mm throttle body, plugs, electric water pump, lightened pulleys( no under drive ones) and of course a stand alone or really good piggy back to tune with. I thought about this cus i got an itch for some power, but now i learned how much its really going to cost.
Old 03-10-11, 09:29 AM
good2go
good2go's Avatar
Stickers, lots of stickers.
Old 03-10-11, 11:02 AM
cartmill
cartmill's Avatar
good NA power?
nope.
Old 03-10-11, 11:51 AM
joe diego
joe diego's Avatar
lol indeed. Big racing stripe!
Old 03-10-11, 12:05 PM
boostinsc
boostinsc's Avatar
What about porting the head? because it's a vvti motor I don't think much can be done and am trying to learn. I just want to have like 300+ hp. enough to beat a stock g37
Old 03-10-11, 12:06 PM
boostinsc
boostinsc's Avatar
Am going to be doing the bfi soon.
Old 03-10-11, 01:32 PM
cartmill
cartmill's Avatar
higher compression, higher octane, more timing, and EMS is about the only way you'll get 300hp non-turbo.
total waste of money, as far as power gains goes.
Old 03-10-11, 02:12 PM
good2go
good2go's Avatar
I can assure you, that's never gonna happen
. . . not NA anyway.
(unless of course, you have absolutely unlimited funds and a lack of common sense)
Old 03-10-11, 02:16 PM
Ali SC3
Ali SC3's Avatar
swap in a v8
Old 03-10-11, 02:48 PM
cartmill
cartmill's Avatar
i'd honestly just put a 75 wet shot on it and knock the distributor back a couple degrees.
Old 03-10-11, 08:58 PM
iwannadie
iwannadie's Avatar
With NA I would just do a full tune up to restore any lost power rather than trying to gain power, just not cost effective.
Old 03-11-11, 03:20 PM
sc4demon
sc4demon's Avatar
dude i thought you were going to no na-t....that would be your best bet to beat a g37 and get 300rwhp man plus i think it be cheaper than to try and achieve that hp na
Old 03-12-11, 11:02 AM
boostinsc
boostinsc's Avatar
na-t is alot right now and i don't have the funds these cars come with like 220hp or something is 70 more horsepower that hard to achieve what about exhaust cam gear? how much hp gain what are the benefits
Old 03-12-11, 12:21 PM
meangreen1
meangreen1's Avatar
Do an overhaul on the engine and a 75 shot.
Quick Reply: What can I do to gain NA Power?
