Replaced clutch slave cylinder pedal still sticks???!!!?!?
recently replaced my clutch slave cylinder and it still gets stuck every once in awhile when i press on the clutch. i heard that if i replaced the master clutch cylinder it will fix this problem just wanted to confirm and also where should i order or buy one for a decent price? advance autoparts/autozone and the local retailers carried the clutch slave cylinder but not the master clutch cylinder.
any help would be appreciated alot thanks. also my driver side window pulls the inside rubber piece with it and it gets stuck so the window doesn't roll back up unless i pull the rubber back out. any suggestions on how to fix this problem?
my master cylinder had this same problem, and never lost fluid. the fluid remained full. However, i determined that the seals were bad. I first replaced the slave and tried to bleed the clutch but to no avail. It could not hold pressure and the clutch would find itself on the floor. Replacing the master cylinder fixed everything and i could bleed it just fine
Try asking in the classifieds, that's actually where I got mine. If not, :
https://www.google.com/#hl=en&safe=o...w=1400&bih=812
I ordered mines off amazon it was the centric brand i believe. First I changed out the clutch slave bc it was the cheapest of the two. Well that didn't work so i changed master clutch cylinder and it fixed the problem. I believe its either or on the slave or the master.
baodalazi
SC- 1st Gen (1992-2000)
03-21-11 10:54 AM
