pte billet 5857...im in love
#31
What are the specs on those two ct12 if you don't mind me asking? If both dyno graphs get posted up I'll show you exactly what I'm talking about.
And what makes you think I'm running stock turbos? I'm not even running a jz engine set btw, and the TWO turbos I'm running are the size of your head.
Okay, I'm off my soapbox. Sorry if anyone took offense.
In for the dyno graph.
#32
maybe this makes us think you have a stock TT 1JZ
https://www.clublexus.com/forums/lex...-and-more.html
or maybe this one Mr.Driftstar:
https://www.clublexus.com/forums/lex...ual-w-bbk.html
hes making 20more hp&tq than i am with a slightly larger turbo.......REAL INEFFICIENT
#34
Anyways, I'm done.......
#35
Non silvia and 93msb....don't waste ur time trying to rationalize with random scrubs. I'm only posting this info for people who have knowledge to share n good feed back. You can find barely any info on single turboed 1j's so I'm just trying to add some results.
Bottom line is my car now is extremely fun to daily drive and has the power up top to play with fast cars. I'm still on stock cams. 264s should get me 450-475 if tunned good. And that's my final goal for this project. Ill get some graphs up this week
#37
I would love to see the graph too., I have a PTE 6262 .63 A/R, w/ 264 Cams, 550 injectors. I am making 414 HP @ 18 psi. 365hp around 4400. I just purchase a .84 divided exhaust housing. But hell i get the same at a lower rpm. I would be happy as hell, I was thinking of going with a QSV. But I would go with smaller turbo and sell the 62.
#38
Nate what ru using for fuel control? And your setup is nice just need to crank tht boost up. I guess ur running a t3 manifold. That should spool fast with the .63.
Sorry.....graphs coming soon.
#42
Small Turbo's FTW.
You see this all the time in DSM land.
You got a "New" guy that has the "Best" of everything. BB 50-trim, Cams, BLah, blah,blah.
He goes to the drag and runs 13.9@ 100 w/ 2.2 60-ft
Then, you got the Veteran that has been ripping 12.0's for 4 years in a row on a "small" EVOIII 16G.
The point is, Small turbo's that are tuned well are more fun on the street.
And in most cases with all the experimentation, faster.
#43
The guys that have plenty info on building the 1JZ outside of Japan would in my mind be the Aussies. Here are two post that I hope will help. Bear in mind that the Aussies dyno are 15% more conservative than a US one and they usually give their figure in kw (multiply by 1.34 to convert to hp).
http://soarercentral.com/sc-forum/me...442/15797.html
http://soarercentral.com/sc-forum/me...75/263663.html
#45
1JZ Single SC400
I have actaully ridden in his 1992 SC300 he converted over to the 5857 just last week. This was the first car that I have ridden in with a single turbo setup and a 1JZ. I was highly impressed. It doesnt start to pull until around 3500 rpm or so. This is a perfect setup for a DAILY DRIVER on a street. He also has the W58 tranny. When we hit 60mph, it was still wanting to spin the rear tires. Al is very knowledgable about his setup and he has done a ton of research on his setup and what his goals were. He accomplished his mission and has a safe, fast, reliable 1JZ with Precision 5857 turbo. He has only got outran by one car, his buddies 240 that is fully built.. Al's is only stock internal, 550 injectors, APEXI piggyback, resistor pack, intercooler, and a few others. Overall I was very, very impressed with his SC300 1JZ sleeper car! This has made my decision to prolly go with a 1JZ instead of a 2JZ..
Al I hope you didnt mind my thoughts and opinions?
