Part II: Engine Upgrades: 2JZGTE T61 R154
#106
car is up and running. I have the fuel pump relay figured out. I rewired the relay and BOOM it worked! It is loud, sounds nice - i have no exhaust. Lots and lots of smoke - injectors dumping fuel in because no DP. I have a couple areas that the oil is leaking on the bolts. Fixed one, need to tighten the other. 1 fuel leak that I need to fix as well and should be good to go.
ONLY CURRENT ISSUE: Headlights!!! I have to find the wire that goes from the dimmer switch to connect it to the headlight relay switch.
I am also going to make sure the coilovers are set at the same height across the board and then going to get it scheduled for an alignment.
xknowonex
SC- 1st Gen (1992-2000)
20
03-07-11 11:46 AM
