Need advice (and probably a motor)
Old 04-06-11, 05:10 AM
KC95SC400
KC95SC400's Avatar
Originally Posted by account2x
Of course I think you would be better off with a 2JZ swap but staying on subject with the UZ I would assume the 2UZ head would flow better. Does it not also have VVT-i? I'd thinking adopting the supercharger to bolt on the 2UZ would be a better option.
edit. the 1uz has a bore of 87.5mm and stroke of 82.5mm, the 2uz a bore of 94mm and 84mm. Correct me if I am wrong but does that not mean you would have to sleeve the 2UZ block deboring it 82.5mm to fit with the 1uz head? The net gain would be only a 1.5mm increase in stroke and an iron block.
http://www.lextreme.com/Lexus-4.7L-Tundra-swap.html
Old 04-06-11, 08:15 AM
cartmill
cartmill's Avatar
dude just get a used jspec 1uz from a good seller on ebay for 800 shipped.
this is what i did when i did a engine replacement for a friend of mine with a 92 sc400.
the engine was PERFECT when i got it, and all cylinders were within like 3psi of eachother...
Old 04-06-11, 09:50 AM
99SC42
99SC42's Avatar
I have a 76k miles 1UZ make and offer it's has been sitting since last year and sooner or later i am going to junk it.
Old 04-06-11, 10:51 PM
account2x
account2x's Avatar
How did they solve the different bore issue?
Old 04-07-11, 05:33 PM
KC95SC400
KC95SC400's Avatar
What year????
So I finally got around to putting some air in the #8 cyl today.
Lots of air (a bit of noticable pressure actually) coming out of the crankcase. Sounded like there may have been some in the intake too but not 100% sure. Nothing from the exhaust.
I put air in #1 just to be sure it wasn't normal. Was some air moving but not near as much.
So I guess that either the rings are gone or possible leaking into the crankcase through the head gasket.
Haven't decided what I'm going to do about it yet.
KC
Old 04-07-11, 05:47 PM
stockhatch
stockhatch's Avatar
As long as spacing on the bore centerlines, and head bolt pattern is the same between engines, I don't see what the problem would be. Engines are bored all the time. Also, bigger bore means unshrouded valves as an added bonus.
That is one expensive *** shortblock though!
Old 04-07-11, 05:51 PM
stockhatch
stockhatch's Avatar
Originally Posted by KC95SC400
What year????
KC
You are a different breed my friend. One of few trying to squeeze good power from a 1UZ. Sorry your engine gave up the ghost, but it gave you some damn fine numbers along the way I hate to even say it, but have you considered an LSX swap? At least it would be keeping to the aluminum V8 roots...
Old 04-08-11, 08:33 AM
99SC42
99SC42's Avatar
93 SC400 i pulled the 1UZ to go 2jz na-t there is nothing wong with it.
PM me i have something you might be interested in...
Old 04-08-11, 12:04 PM
RedPhoenix
RedPhoenix's Avatar
and adding GM roots
You would be surprised on how many people are making good power from 1uz's.... maybe not in the SC crowd since most here are like "JZ JZ JZ JZ JZ" but elsewhere... there are plenty of other vehicles with a 1uz playing with power (swapped).
Old 04-08-11, 12:16 PM
KC95SC400
KC95SC400's Avatar
Ya, if I wanted a car with an LS motor I'd buy a car that came with one....
I love the uz motors too much and I'm just a Toyota guy I guess...
KC
Old 04-08-11, 02:19 PM
stockhatch
stockhatch's Avatar
I hear what you guys are saying. I don't blame you for wanting to try for power with the underdog. Heck, Honda guys do it all the time. LSX swaps ARE kinda cheating since it is so easy to make power with one.
Old 04-08-11, 03:51 PM
sc4doubleO
sc4doubleO's Avatar
This sucks. Broken ring lands?
Old 04-08-11, 06:19 PM
BartleDoo
BartleDoo's Avatar
Come on man let's leave the JZ out of this for once please. Back to the engines at hand. The 2UZ is a truck engine and has worse cams that the 1UZ. Correct me if I am wrong, but the power peaks at 4800RPM stock. That's no fun. Also, the rods are tiny!
To the OP, I think you should revert to an early thick rodded 1UZ if you aren't going for an all out build. The tune won't be that different so you won't need to change much. You will be able to run more boost with one without worrying about those baby rods you have now. Just be careful with the sparkv advance this time around! Glad you are sticking with a UZ though. Good luck.
Old 04-08-11, 07:22 PM
xspsi6
xspsi6's Avatar
You just use the 4.7 lower end with 1uz heads so it's just plug and play^^
Old 04-08-11, 07:34 PM
BartleDoo
BartleDoo's Avatar
Yea I've heard of that. I was actually just referring to him saying to use the entire 2UZ (head and all) which would not be so beneficial.
Quick Reply: Need advice (and probably a motor)
