Map ECU 2/Tuning on a 1jz
Excuse my ignorance but i couldn't find this information anywhere across supramania, supraforums, or clublexus.
Does anyone know what the map clamp voltage is on a 1jz? I'm reading around and it states that the clamp voltage on a 2jz-gte is 4.3volts. In some posts, I read that the 1jz clamp voltage is 4.9? how is that possible? Can anyone who has tuned please look at their maps to see what the voltage is? For those who don't understand what this is, it is the voltage that is supplied to overcome boost cut. This is overcome by using a engine management unit or boost cut controller/fuel cut controller.
My second question is, I'm trying to tune boost control but I'm confused about the controls. I understand target boost pressure and sensitivity but I do not understand gain, duty cycle, and cDutycycle. I think this information is universal across all boost controllers.
Thanks guys
Thanks guys
i did go to their support site and the performance research forums. the only reason why i ask here is because the duty cycle concept is universal across all boost solenoids. thanks for the suggestion though =]
the clamp voltage is 4.3 on the 1jz therefore if you hit that voltage the car will boost cut. Don't worry about what you put in the clamp voltage because your ecu can still boost cut it. On the tunning map is where you limit the 4.3 thats how I'm doing it, on 20 something psi I set my numbers to 4.28 or something to make the car fuel cut if I accidentally overboost (pop wastegate hose). this is what I use for my 1j with 550cc inj if you got more questions feel free to ask me via pm.
and don't use the built in function to control a boost solenoid it sucks. all the duty cycle and what not stuff is explained in the map ecu manuals that are online. remember there are 2 different manuals one is for use the other is for installation so don't confuse the 2.
okula247
Performance & Maintenance
07-15-10 06:03 PM
