'97 400 transmission
Check the GAUGE fuse in the driver's side fusebox. It supplies power to the switch which sends the signal to the ECU to tell that you have moved the shift lever.
Does the car start?
If so, when you put it in various gears, does it show this on the gear indicator lights?
Does the car start?
Dear BugJug and others:
I have no idea why the MAF might have anything to do with the automatic transmission. But, I did what xspsi6 suggested and it worked - for about 3 minutes. I put the car in reverse to get it out of the garage (so I could clean the floor) and then when I attempted to put the car back in the garage, I got nothing. Attempted again with the MAF thing and had no luck. Recruited some neighbors to push the car back into the garage.
I'm quite willing to check the GUAGE fuse if you can tell me how to access the fuse "box" that's located under the carpeting (driver's kick plate?). It's most unaccessible. I'm about to take a razor blade to it.
The car starts without any problems.
And the gear shift moves easily from one gear position to the next. But, the car does NOT go into gear.
When I move the gear shift lever, the gear indicator lights indicate the gear that the car should be in. But, it absolutely does not engage.
So, what's next?
ThreePutt2
So, what's next?
ThreePutt2
xspsi6,
That's not the best news I've ever gotten. Just to make sure I understand - you're saying that the transmission is probably shot but it's possible that the problem could be remedied with a new pump? Again, keep in mind you're dealing with an automobile dummy. If I'm looking for that "pump," do I simply say I need a transmission pump for a '97 SC400? or is there some other description of what I might need?
Is there anything else we can do to determine that the pump is actually what we need?
ThreePutt2
ThreePutt2
ThreePutt2
ThreePutt2
Well that is the best diagnosis I can give over the internet with out being there to test it first hand but like I stated these transmissions can be had for dirt cheap used so that is a plus.
It is quite rare for a trans to fail in one of these cars as they are usually super dependable however the wrong type of fluid if it was ever changed out before you got the car will kill it like this but it usually happens quickly.
Yo may as well have a good used transmission installed as opposed to just replacing the pump since the trans would have to come out and apart to do this.
-bug
So, what's next?
ThreePutt2
So, what's next?
ThreePutt2
abounly
Performance & Maintenance
06-02-10 01:41 AM
