sc300 na-t *turbo blew apart* !!!!
I need to take out the union bolt and see if some thread sealant got in the feed clogging it..
that's why i don't small ARs ....
With my Billet67 i was told to use an oil restrictor with my -4 feed never did and never had a problem.
The Precision tech told me to run -3 feed, but my feed was -4 i just went ahead and used it.
Some people don't like Anti Surge housing because "it makes less power" which i don't believe.
Wow thanks for all the replies guys..this forum is so much more of a help than clubna-t where I used to go..
I also think the main reason the turbo died was from oil starvation..the way you guys are describing,that oil feed line should have some good pressure/flow ...my feed is drip..drip..drip ..
Deff gonna take off the feed see if its clogged get it working properly before the new turbo goes on..and get rid of the restrictor ,thanks again guys -chad
Lanceezy
Performance & Maintenance
10-14-09 09:46 AM
soarer NAT
Lexus Vehicles Classifieds
16
08-19-09 04:59 PM
