sc300jz's 5spd swap
#62
Make sure you install the rms correctly, torq the flywheel bolt to spec, install the pilot bearing correctly, use the alignment tool, and go from there.
you will have to cut a little bit in your tunnel but no big deal, instead of using a cutting wheel i use a hole saw it make the job easier and cleaner.
Don't over tq the flywheel bolt because they break and i broke one in the past.
GL
GL
#64
I got the spline to sit in the pilot bearing i believe, cause when i tilt the transmission the engine tilts as well. i just can't fully sit it in; theres about a inch and a half left..
@ quicksc4 - i installed everything correctly, its just not slipping in!! ugh, how annoying
#65
Finished, finally.
http://www.youtube.com/watch?v=kUA6M3N2_l4
Started up on the first try. It was too late to keep the car running i'll try again tomorrow morning.
My mind/body is fried from working nonstop for the past 3 days so don't mind my excitement for it starting on the first try.
#67
wow congrats my man. unfortunately some other things have come up so i could not purchase my 5speed swap
but the saving for a 1jz swap a long with a R154 has begun.
can't wait to see all the pictures.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#68
Thanks guys, here is a little teaser i guess you would say
since my friend hit the stop button on the camera.
http://www.youtube.com/watch?v=2Hu931fXcdw
Got the other one to upload.
http://www.youtube.com/watch?v=Dh3HQ0oYuB
#75
No problem buddy im happy it all worked out for you.
I was the same way i planned on taking so many pics but once i got stated it just never happened lol
