sc300jz's 5spd swap
Old 06-08-11, 01:32 PM
  #31
abounly
abounly's Avatar
Well i just did a oil change and, my rear main seal is leaking like a ****.
Anyways i was wondering if i have to take off the RMS bracket (according to redphoenix) but in this thread this guy didnt. http://www.lexls.com/tutorials/trans...n/removal.html
Also, is there a gasket behind the RMS bracket?
Old 06-08-11, 02:15 PM
  #32
99SC42
99SC42's Avatar
Yes if you remove the RMS bracket you will have to use some rtv to reseal it. it's more expensive with the bracket on it.you can just buy the seal itself and replace it, it's not to bad.
Old 06-08-11, 02:25 PM
  #33
abounly
abounly's Avatar
Yeah if i am going to take off the bracket i'll go and grab toyota fipg. What do you mean more expensive with the bracket on?
I already ordered the seal and am just wondering if i were to take off the bracket would i need a gasket (or would it come with the seal)
Old 06-08-11, 04:58 PM
  #34
SC YAA
SC YAA's Avatar
Yay finally Get it done buddy!!!
Old 06-09-11, 07:32 AM
  #35
kez
kez's Avatar
hey i have that clutch lol
i remember when i did my swap last spring. i had the chance to pull my whole engine which made it so much easier. but my clutch pedal still squeaks like its new every time i push it in kinda annoying but the swap was well worth it.
Old 06-10-11, 06:14 PM
  #36
megamax
megamax's Avatar
effing wow. this is the writeup i needed. thank you.
Old 06-10-11, 06:54 PM
  #37
abounly
abounly's Avatar
6 more days till I pull the tranny!
Just got some red loctite and a Electric saw today. Hope my RMS arrives before I start
Old 06-14-11, 03:59 PM
  #38
abounly
abounly's Avatar
Just got my RMS today and returned the electric saw and got a air grinder since i already have a air compressor.
Sadly the swap will have to wait till june 19th
Old 06-14-11, 07:26 PM
  #39
vinh
vinh's Avatar
Nice, good luck on the swap! Are you going to be using the W58 from Tom's car?
Old 06-14-11, 08:10 PM
  #40
abounly
abounly's Avatar
Yes i am, we were able to get it to run after we bought it wasn't in the best shape. Shifted a little rough, but after draining the transmission i could see why since white fluid came out then orange. I'm sure with new tranny fluid it'll run completely fine.
Old 06-14-11, 08:34 PM
  #41
meangreen1
meangreen1's Avatar
Clean car man, I like the black on black too!!!
Old 06-14-11, 09:04 PM
  #42
sleepy1785
sleepy1785's Avatar
clean swap so far i used yours and the other thread to do my swap last weekend man u have to cut alot for that shifter, good luck
ps u got that clutch master in perfect took me a couple trys to get the pedal to sit right slso my harbor frieght hole saw broke on me as well
Old 06-18-11, 12:43 PM
  #43
abounly
abounly's Avatar
Thanks, tomorrows the big day
BUT i have a few questions hopefully someone can chime in.
Am i suppose to grease / lube anything on the manual tranny. I THINK your suppose to lube the tip of the spline where it connects to the pilot bearing. Can anyone confirm?
Do i need 31481A from the manual tranny? Or does the auto have one as well? If it doesn't i guess i gotta go make a run to my buddies place to rip it off the SC donor.
Old 06-18-11, 06:00 PM
  #44
Initial J
Initial J's Avatar
in, picking up a complete W58 swap from a 99 sc300 locally so this DIY will help a lot.
Old 06-18-11, 06:12 PM
  #45
Sk8tehwake
Sk8tehwake's Avatar
car looks good...5 spd swaps are cake. good job
Quick Reply: sc300jz's 5spd swap
