Sc400 tranny...solenoid connector?
Old 06-10-11, 06:35 AM
mktbully
mktbully's Avatar
Default Sc400 tranny...solenoid connector?
Picked up a tranny and the connector to the solenoid (i believe it's the solenoid) has 8 wires where my tranny has 6 wires.
my car is a 92 SC400...i assume this came from a newer SC or something?
any ideas if the tranny will still work? is there a way to bypass the other 2 wires or something?
Old 06-10-11, 07:19 AM
mktbully
mktbully's Avatar
plug on donor transmission...
plug on the old transmission is the same as this...
Old 06-10-11, 08:29 AM
cartmill
cartmill's Avatar
yea buddy i think the 95+ transmissions had two more terminals on the plug, making them an 8 pin connector.
Old 06-10-11, 08:51 AM
mktbully
mktbully's Avatar
so any way to get around this? swapping VBs? is it as easy as dropping the pan and swap wiring harness from the solenoids?
Old 06-10-11, 09:46 PM
MooJohn
MooJohn's Avatar
Could it be for the kickdown that was a cable on the 92 and switched to a solenoid on newer models?
Old 06-13-11, 11:26 AM
mktbully
mktbully's Avatar
the extra 2 wires looked like it was for a temp sensor or something.
dropped the pans and the harness swaps over.
vegaswins
11-27-14 07:26 AM
CRuby
06-06-10 11:28 AM
klymax77
04-11-08 07:00 PM
Rexn30
11-01-07 04:35 AM
Quick Reply: Sc400 tranny...solenoid connector?
