R154 leaking.......again! Need advice please
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
So I spent a half of a day trying to fix my leak from the shifter housing, but I looked today and its leaking again. Looking at it closely I noticed its coming from the back 2 bolts of the 6 that pinch the rubber gasket. I tried using RTV and resealing it but it still leaks. Does anyone have advice to fix this for good?
You cant just tie it back in at a lower level because if it starts back filling with oil on the low end it wont vent any more. Meangreen1, you could try venting it, but you must have another issue if it is leaking. How much power are you making, how high do you rev, and how full is the tranny? Also, what kind of fluid are you running? It could be frothing if you are spinning the trans high enough.
well I have sealed it twice and its still leaking. As for power I am making 330WHP at 6K. Regardless of my driving I still see fluid leaking. I did a stroll under 3K and it was still leaking. I am also using Redline fluid, but I dont see how thats the issue.
at 330 whp , thats weird i had that issue like i told in your other thread but people didnt think i was serious, mine leaked past 500whp .
install the breather if that doesnt fix it i would get it rebuild by a professional. mine was worst
