aristo wiring experts needed
Good morning guys and gals.
I have a 94 Sc300. The car is in need a some serious love. The reason that I need wiring help, is because my car was wired by a guy that left the job unfinished. I took he harness out of the car and started repairing what was left unfinished.
I have read so many of the threads on this site and supraforums, But I am confused (More like lost) on a few wires and where they go. I am hoping that you guys can help me out.
Let me say thank you to Lexsingle for the info that he has already provided.
The two connectors behind the battery (EB1 & EB2) have wires coming out of in that are not connected to any wires. I did find some info on here. What is causing me a problem, is that the wires go to a plug called C1. I dont know where this plug is. So this is my first issues.
From the post that I read here on CL, It said that:
8 wire plug EB1
• Blue –Blue from old AC connector
• White – White of C1 plug
• Black/Red – Black/Red of C1 plug and Black/Red of EB2
• Black – Black of EB2 and Yellow of old alt plug
• Black/Orange – Black/Orange of C1 plug
• Black/Yellow – Black/Yellow of C1 plug
8 wire plug EB1
EB1 pin 4 (Black/Yellow)goes from 30 amp EFI fuse to small ecu connector, pin 33 BATT.
EB1 pin 8 (Black/Orange)goes from EFI main relay to small ecu connector pin 24 M-RELAY.
EB1 pin 6 (Black/Red) goes from ABS relay pin 5 to data link check connector pin 23
EB1 pin 1 (Lavender) goes from ac clutch relay pin 3 to ac clutch pin 4
EB1 pin 2 (White) goes from ac clutch relay to small ecu connector pin 23 ACMG
EB1 pin 7 (Brown) goes from ac temp sensor to Il1 pin 1 and ac clutch pin 1
EB1 Pin 3 (Black) goes from starter relay pin 1 to various places depending on if the car is auto or manual. Let me know if you need more info on that one...
I think that is it.
I think that is it.
pin 1 blue a/c compressor
pin 2 white a/c clutch magnet relay to ecu
pin 3 black clutch safety switch
pin 4 black / yellow BATT to ecu
pin 5 blue /red trac
pin 6 black / red WB in diagnostic port
pin 7 brown a/c compressor
pin 8 black / orange M-REL to ecu
would you happen to know where the brown, blue w/ grey dot, and white wire goes?
At any rate, ignore the C1 stuff. It is not correct, or applicable.
I consider the connectors you are working with to be "body connectors". Even so, I don't think they jumper to any other body connectors except where I listed multiple connections.
I think that is it.
I think that is it.
