Need help Wiring a Apexi SAFC
Im looking at the manual and wire diagram from the Apexi site. It looks pretty straight forward, just 6 wires.
-Red (Power)
-Green (RPM)
-Brown (Ground)
-Black (Ground)
-Yellow (A/F Pressure Signal Output)_
-White(A/F PRessure Signal Input)
My question is on the wire pinout diagram theres 2 RPM pinouts-1 RPM signal and 2 RPM signal. Which one do I use? Theres only one RPM(Green) wire from the SAFC.
And the Throttle signal, what color wire is throttle signal on the SAFC?
Diagram in the bottom link on page 14, diagram T8-A
http://www.supracentral.com/manuals/...ual_wiring.pdf
-Red (Power)
-Green (RPM)
-Brown (Ground)
-Black (Ground)
Are the wires the same on the V1 as the SAFC2? Im tryna figure out the throttle wire and cant find anything on the version1, on the V2 throttle wire is GRAY. I wanted to get a clear answer before the install
Yeah bro, thanks for the pinout. I got the damn thing installed but Im having problems tuning it, it was running good yesterday. Got rid of the Stutter that I been having for the past 2 months finally.
I think I have a loose connection somewhere cause when I fired the car up today it was missing big time and stalled out a few times.
