My new custom exhaust for my 98 SC430
Old 07-14-11, 02:02 AM
  #31
LXLUTHR
LXLUTHR's Avatar
Originally Posted by spdrcr771
I really dont want to be the bearer of bad new's. But there is a big reason Im switching back from my 2.25" mandrel bent X pipe true dual cat to rear setup. When I went from stock exhaust to the 2.25 X set up, I lost bottem end torque. Then I added S&S headers & I lost even more bottom end torque. Oh I had this slammin midrange & top end power but before 4K when the vvt-i kicked in, slug. Just look @ my dyno #'s in my sig. 1st one 400 w/x pipe. 2nd one 430 w/headers & X pipe. I gained 31whp & only 10lbs of tq. bcsc400 on here has a 99SC400 & he did this exact same Y pipe setup im posting here & his dyno's were (& I know every dyno is different) 270whp & 270wtq, & he's not even 430. So that being said. This is my 5th 400, 1st vvti & ive done this same X pipe on all my cars & its the same result. These car's were designed with a Y pipe & w/only 4 liter's of displacement & a very short cam duration over lap, thats what they need. There are several GS400/430 guys on here that are making the same 260-280 whp on the stock Y pipe.
1. 2.5" is too big
2. X pipe is not as good as Y pipe.
Originally Posted by bcsc400
Looks good. I can't wait to see the results.
LXLTHUR, take spdrcr771's advice.
X-pipe = bad
2.5" = bad
Hey THANKS fellas for the info! Soo a Y-pipe with 2.25 piping, remove all of the stock resonators straight to my Top Speed Pro 1 mufflers? Too bad the Top Speed Pro 1 muffler piping is 2.5 inch...gotta sell the X-Pipe now haha! Anyways, spd where are the video sound clips?!?
Old 07-14-11, 12:10 PM
  #32
Candela
Candela's Avatar
OKay cool sooooo when are u gonna post up a video?? lol
Old 07-14-11, 02:34 PM
  #33
spdrcr771
spdrcr771's Avatar
Keep the stock Y pipe. Cut it off right behind the Y. Use a 2.5" mid pipe then buy the rear Y pipe I got, which is 2.5 into 2 X 2.25 then just run 2.25 to the axle backs make a flange & bolt up to the 2.5 Top speeds. The important part is the stock Y pipe into 2.5 mid pipe. Thats what keeps the low & mid range torque. After that its not that important. The other important part to making 20+ whp is the headers.
here is a link to the rear Y pipe I bought.
http://www.mandrelbendingsolutions.c...sh-Pipe/Detail
Old 07-15-11, 07:41 PM
  #34
spdrcr771
spdrcr771's Avatar
Default Update: New exhaust video clip.
Here is the video clip yall were looking for.
http://www.youtube.com/watch?v=7SwI48Txp1A
Old 07-15-11, 10:12 PM
  #35
Bigzavs
Bigzavs's Avatar
sounds real damn good, probably even better in person
Old 07-15-11, 10:22 PM
  #36
ThomasGS4
ThomasGS4's Avatar
Sounds fantastic! I needa hear this in person.
Old 07-15-11, 11:04 PM
  #37
Kira X
美少女戦士セーラームーン
Kira X's Avatar
That sounds great! I've got to hear it in person.
Old 07-16-11, 12:33 AM
  #38
spdrcr771
spdrcr771's Avatar
Thanks to all yalls post. Yesssss it does sound way better in person. Thanks Bigzavs' Parker, & Kira X. Kira, im not sure when your in NT, but dude you gotta come to one of our Tuesday night meets. Thanks to the local boy's.
Old 07-16-11, 03:10 AM
  #39
Joey-E
Joey-E's Avatar
Nice sound!
Old 07-16-11, 06:42 PM
  #40
Egone
Egone's Avatar
nice work sounds awesome
Old 07-16-11, 06:50 PM
  #41
97-SC300
97-SC300's Avatar
Holy F***. Damn that sounds badass.
I got a full Tanabe exhaust on my GS430 basically because I wanted to tone it down with that car since the SC is the project.
But man.... Now I want the GS430 engine in my SC after hearing this. I am still rolling around with no mufflers since my **** got stolen. I can't decide what exhaust I should buy. I need to make a thread.
Badass work my man! So nice.
Old 07-17-11, 01:36 PM
  #42
spdrcr771
spdrcr771's Avatar
Thanks man. Yea I couldnt believe that happened to you. Ppl are F'd up these days. Well youve already had the blitz, i guess you got to get the fireball megas. I know they are pricy but look sweet.
Old 07-20-11, 09:03 AM
  #43
JBrady
JBrady's Avatar
Couple of added thoughts here:
As noted KEEP the stock FRONT Y-pipe which merges two into one.
Cut AFTER the two pipes merge into one leaving apx 1" of the stock center pipe.
Use 2.5" tube for the middle single section OR get a TRUE 2.5" resonator which will have a SMOOTH internal surface that is at least 2.37" inside diameter. The Top Speed that I bought is not a true 2.5". The outside is 2.5" but the inside necks down to 2.13" and has sharp edges in the flow.
See the following link for pics on the TS resonator issues.
https://www.clublexus.com/forums/per...ml#post6546860
You want ALL pipes to slip inside the pipe it fits into in the direction of flow OR be smoothly butt welded with no slip. Do not use slip fit against the flow.
You can replace the REAR Y-pipe, which splits from one back to two, with the link given above by spdrcr.
Any rear mufflers including stock will work. If you use stock select the 2.5" to 2.0" rear Y pipe to split the exhaust gasses and make any transition between pipe sizes SMOOTH.
Old 07-20-11, 02:59 PM
  #44
mr/griffin
mr/griffin's Avatar
ARGH! why dont they have a 4inch builders kit?
Old 07-21-11, 06:34 PM
  #45
spdrcr771
spdrcr771's Avatar
I didnt look for the 4" kit but this is another resource for piping.
http://www.mandrel-bends.com/catalog/
http://www.spdexhaust.com/
Quick Reply: My new custom exhaust for my 98 SC430
