Engine is finally starting give up?
Old 07-22-11, 12:23 PM
SC300_704
SC300_704's Avatar
Default Engine is finally starting give up?
this engine has over 317k and been running strong for over 1 1/2 years, i notice it started to tick/knock a few months ago not sure what is causing it. this is on a cold engine start but goes away after engine is fully warmed up. first thing that comes to my mind is when i took the head off to replace the HG, i tilt the head over and all the shim buckets fell out. at that time i didn't know much about them so i just cleaned them best i could and randomly put them back on. what does this sound like to you guys, valves, bearings, etc.? btw don't mind the exhaust leak.
http://www.youtube.com/watch?v=pIv24_tUrmA
Old 07-22-11, 01:18 PM
stockhatch
stockhatch's Avatar
Sounds like rod bearing to me, but it is kinda tough to tell from the video.
Old 07-22-11, 01:22 PM
stockhatch
stockhatch's Avatar
Now that you know more about the shimming process, why don't you pop the valve covers and check your lash? Maybe you will get lucky and a valve adjustment will fix it What is the oil pressure doing?
Old 07-22-11, 02:00 PM
SC300_704
SC300_704's Avatar
i hope it's not but if it is then i'm just gonna keep driving it like this until i get the gte swap.
i will have to take a look at the clearance once it's not hot outside. the oil pressure seems normal, around 70-80 psi then once the engine is warmed up it drops to about 25 psi.
Old 07-23-11, 12:20 AM
SC300_704
SC300_704's Avatar
the more and more i watch youtube videos the more i believe it's a rod knock which means it's the bearings b/c a lot of those videos makes the same sounds as mine does. can a rod knock go away after the motor is fully warmed up?
Old 07-23-11, 01:47 AM
levie
levie's Avatar
i dont think so^ but damn, thats a crazy amount of milage.
Old 10-30-11, 02:37 PM
SC300_704
SC300_704's Avatar
just wanted update on this situation...found out today it was just a big exhaust leak where the turbo manifold meets the head. car is running so much better already. time to turn up the boost!
Old 10-31-11, 09:53 AM
stockhatch
stockhatch's Avatar
Awesome! Gotta love the cheap, easy fixes Why can't I ever get a cheap easy fix?
Old 10-31-11, 12:24 PM
ihiryu
ihiryu's Avatar
you ain't lying.
to OP: I guess you got really lucky!
Old 10-31-11, 03:59 PM
nlc
nlc's Avatar
What about ur oil pressure dropping to 25psi? Isnt that a concern anymore? Ur still lucky it wasnt rod knock.
Old 10-31-11, 10:17 PM
SC300_704
SC300_704's Avatar
thanks man! i've been very lucky w/ this engine haha.
Originally Posted by ihiryu
you ain't lying.
yes i did lol.
it's only at 25 psi when the motor is fully warmed up and during idle.
Old 11-01-11, 08:41 AM
spoolxexo
spoolxexo's Avatar
25 psi is better then 0!
tn96dc
10-30-13 02:41 PM
new2005GX
GX - 1st Gen (2003-2009)
22
09-19-13 10:39 PM
Monkiee
08-16-09 02:20 PM
ArcherIII
RX - 1st Gen (1999-2003)
04-07-08 08:43 AM
swiggins
05-06-07 08:18 AM
Quick Reply: Engine is finally starting give up?
