My 1jz R154 problems
Ok so I picked up an sc400 with a 1jz swap. It had the a340, but something was off in the wiring or ecu so it was in limp home mode. This sent me into the world of the R154. Now heres the thing, with the 1jz, theres going to be the tach problem, I got the msd tach adapter. Cannot seem to locate the igniter to pull the signal from, ended up having a friend hook it up, I think he used the cam position sensor. Now it works, but reads about 1k under.
Problem number 2 is the speedo. I saw one thread on what parts to use and an old Marlin Crawlers link that doesnt work. Is there a better and hopefully cheaper option?
Does any one thats done the R154 swap have an issue with a ton of hot air coming in under the center console?
Milenkoben Ok so I picked up an sc400 with a 1jz swap. It had the a340, but something was off in the wiring or ecu so it was in limp home mode. This sent me into the world of the R154. Now heres the thing, with the 1jz, theres going to be the tach problem, I got the msd tach adapter. Cannot seem to locate the igniter to pull the signal from, ended up having a friend hook it up, I think he used the cam position sensor. Now it works, but reads about 1k under.
i wanted to take it from the igniter, but where the hell is the igniter on these? its a 97. i guess he got it working with the tach adapter and a resistor, its off about 250 rpm
