Auto to manual tranny swap
You will need a driveshaft. most likely just the front half of an SC300 shaft (may or may not need to be cut I'm not sure)
check here as RedPhoenix mentioned: www.quantum-auto.com
You will need the Quantum kit, pedals from DM, SC300 With W58 driveshaft, Shifter boot, Clutch master Cylinder and lines, W58 for 92-94 or 95-97 they both work but the 95+ will work better.
This conversion is not cheap , special the quantum kit but it's a nice kit .
I just did this conversion for another member on here.
My thread has another way to go about the same swap. If I were you I would do alot of research if you are serious about this swap because sourcing parts is the hardest part. I thought at least.
https://www.clublexus.com/forums/per...few-weeks.html
mbagang
Performance & Maintenance
29
10-18-12 08:26 PM
