sc300 leaking oil
its leaking some brownish oil. i changed my oil so i know its not that. the leak is somewhere located next to where the a/c water drips down on your car. next to the driver side wheel. can anybody diagnose this problem or have had it? please and thank you ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Im stumped now..any oil on or around the head/valve covers of the engine? Hows the mounting surface and threads where your oil filter sits? Is the oil filter clean, or coated in oil on the outside surface? Car is completely factory right? No na-t oil feed lines to worry about? (here i go with all my questions again)
I misread your first post yesterday and for some reason was thinking passenger side. My fail.
Best bet is to clean off the area very well and use appropiate dye in suspected pil and trace it with a black light and uv glasses. Brownish color would indicate engine oil to me and I have oil in the same spot on my engine from my cam seals leaking . I would look behind the distributor on the pass side of the head . Also better pics would help can't see much with what u provided.
The only thing that would be o. The drivers side of a 300 in the oil filter and if not properly cleaned might drip onto your subframe check that out as well
would it be best to take it to a mechanic? the oil filter is on pretty tight. i mean i just changed the oil 3 weeks ago. if it was leaking engine oil wouldn't like the clear yellow? so that makes me alittle confused. there wouldnt happen to be any other liquid thats brownish?
It could very possibly be a bad rear main...lift the front of the car, soak everything underneath in Gunk foam engine cleaner/degreaser, let it sit for about 10min, soak it again, then power wash the entire bottom of the car. This will not only clean everything, but it will help you track the area down a bit easier as to the source of the oil.
And yes oil is a light golden color, but you have to take into account that as its running down the engine, chassis, or wherever it is picking up road grime, dirt and old oil deposits from the surrounding areas..thus when it hits the concrete, its much darker.
Could be several things. Once you get the belly pan off and clean it you should be able to track it down, but it's probably:
PS fluid
AC compressor (the front seal on the pulley will leak)
Front crank seal
Good luck.
PS fluid
Front crank seal
Good luck.
