Sc300 fan blower stopped working!!
It was working fine and when it stopped I gave it a couple hits and itll work fine but after a 2 weeks it completely stopped working. I searched around on here but couldnt find much for an sc300. Any ideas?
I just replaced the blower motor and fan in my Toyota Camry (virtually the same part), and from what I understand, The one in the SC is in the same location. Remove the passenger side, lower dash and it is up in there somewhere, near where the cabin air filter slot is.
Its a relatively simple job, but if you dont go aftermarket, the motor might end up spinning the wrong way after connecting it, to solve this you just cut the two wires, and put them back together but opposite. eg. if you have a blue wire and a black wire, cut them and connect blue to black/black to blue.
Hope this helps.
Hope this helps.
so i am having this very same problem with my sc300 97 there was some foil that fell in and i think that ****ed burned something out, i have ordered a new fuse, and tried replacing it. after turning it back on nothing work still, all of the a/c buttons do no work, nothing lights up for it
what could else could it be? im not too experienced with a/c units, i've only assisted in my brothers installation of one
if the motor works then you're at the same spot i'm at, still trying to figure out why the motor won't spin but everything else is working. if the motor doesn't work then you have a fried motor and you can go ahead and buy a new one, unless you know how to rebuild it. hope this helps someone a bit.
Did anyone on this forum ever figure out this problem? I am currently having the same difficulties with my 1991 LS400. My blower works when direct power is hooked up to it.
I have replaced the following
Resistor
Transistor
Climate Control Assembly
Resistor
Transistor
I’m in the same boat. And at my wits end.
[QUOTE=JJAUTOWERK;6611242]It was working fine and when it stopped I gave it a couple hits and itll work fine but after a 2 weeks it completely stopped working. I searched around on here but couldnt find much for an sc300. Any
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20190222_100720_65f88bfd281324e19dc4c6cf85cccb67e07dced5.jpg)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20190125_135308_hdr_458429ce75e394b3ff434abfeeb31dd6fb4b937f.jpg)
