JDM 2JZGTE guys... what downpipe are you using?
Old 08-23-11, 08:44 PM
97-SC300
97-SC300's Avatar
Default JDM 2JZGTE guys... what downpipe are you using?
What downpipe works with a stock SC300 muffler system and a JDM 2JZGTE? Do you have to get it custom made or is there someone that sells it?
Old 08-23-11, 11:57 PM
soarer13oy
soarer13oy's Avatar
I believe you can buy one on ebay.....
Old 08-24-11, 05:52 AM
99SC42
99SC42's Avatar
Yes you can buy it on ebay like ^he said, when i did "Fuzion" swap he had bought one you can Pm him to get the info or i will get him to post the link.
Old 08-24-11, 06:12 AM
stockhatch
stockhatch's Avatar
http://cgi.ebay.com/ebaymotors/Supra...item1c076bff30
This is what you need. Bolts right up to the stock SC exhaust as well.
Old 08-24-11, 06:48 AM
97-SC300
97-SC300's Avatar
Thanks for the help guys... is that a quality downpipe for those who have seen it? A stock MKIV Supra downpipe will not work then?
Old 08-24-11, 07:10 AM
99SC42
99SC42's Avatar
It's thin metal but it's works and looks great , the stock supra DP will not work because the flange .
IIRC the supra has a 2 bolt style flange and the Aristo is 3 bolts style flange right of the Turbos.
Supra DP will not work unless you modified it.
Old 08-24-11, 07:12 AM
93MSB
93MSB's Avatar
double check with what quicksc4 said if the flange matches up you can use a MKIV downpipe and midpipe, the catback on the other hand is different in length IIRC
Old 08-24-11, 07:29 AM
93MSB
93MSB's Avatar
OK quicksc4 is correct, the flange on the USDM supra is a bit bigger than the JDM. The flange is also clocked at a different angle (probably for clearance of the steering since its RHD)
heres a thread with pics off the differences: http://www.supraforums.com/forum/sho...=1#post3572141
the easiest thing to do would be buy an aristo specific downpipe
your other option is to buy a USDM downpipe and have it modified to fit
Old 08-24-11, 07:36 AM
stockhatch
stockhatch's Avatar
The downpipe I linked to is a JDM downpipe. It will work on any JDM 2JZGTE, including an Aristo 2jz which I have. The JDM downpipe flange at the turbos is 3 bolts, but a smaller, different pattern(and probably angle) than the USDM, which is why you can't use the USDM downpipe on a JDM engine.
Old 08-24-11, 07:41 AM
stockhatch
stockhatch's Avatar
And as far as quality, it looks and fits great and I think it is a fair price for a nice part. I offered less than the asking price on the auction when I got mine and they took the lower offer just FYI.
Old 08-24-11, 08:00 AM
99SC42
99SC42's Avatar
^Adam you are correct that's the exact dp i had installed on Fuzion swap it's fit perfectly no modification require and comes with all the hardware it's PNP .
it's a nice piece and the price is right..
Old 08-24-11, 08:22 AM
97-SC300
97-SC300's Avatar
Thanks guys. Ordered
Old 08-24-11, 02:24 PM
97-SC300
97-SC300's Avatar
what did you offer him? i offered up to $98 which I though was fair and he declined...
Old 08-24-11, 02:31 PM
stockhatch
stockhatch's Avatar
I don't recall. Let me see if I can look that up in my history...
Old 08-24-11, 02:33 PM
stockhatch
stockhatch's Avatar
Looks like I ended up paying him $100 for it.
Quick Reply: JDM 2JZGTE guys... what downpipe are you using?
