My 1jz has AC!
Old 09-10-11, 05:17 AM
joe diego
joe diego's Avatar
Default My 1jz has AC!
Just added one can of R-134a Quick Cool (14oz can) to low side service port. I'm happy that the AC is cold but should I add another can? I'm using the same compressor that came with my 93 2jzge. The can said "stop leak, Oil Charge, and O ring conditioner. Cost me about 22 bucks at auto zone.
Old 09-10-11, 09:29 AM
vangb2
vangb2's Avatar
Service tech don't use cans to determine the amount it takes to fill up. They use a tools that measures weight. Also stop leak will contaminated your system.
Old 09-10-11, 04:19 PM
joe diego
joe diego's Avatar
^^^^ That's great but I'm not a service tech. nor do I have the proper tools. Anyway, if anyon has done this before I would appreciate some information that would help me out.
Today was really warm and it is not blowing as cold as I want. Not sure if I should add some R134 with oil or not.
Old 09-10-11, 04:27 PM
Vwpride12
Vwpride12's Avatar
Does your can have avpressurevgauge on it?
Old 09-10-11, 05:08 PM
lex92sc300
lex92sc300's Avatar
get can with the gauge set up use the gauges and fill to the proper poundage.. instructions on can will tell you .
Old 09-10-11, 05:12 PM
soarer93
soarer93's Avatar
My 1jz soarer says on the hood :
R12 charge
Max: 2.2 lbs (1.0 kg)
Min: 1.98 lbs (.90kg)
so for converting a r12 to r134 system - basically says not to exceed 80-85% of that amount when using r134 in a system that was originally r12.
so IF you happen to have yours converted..
dont use more than .8kg which is 1.76 lbs of r134
from an EMPTY system.
your cans will tell you it is equivilant to
1.2lbs or r12 or 1lb of r134. (but check your can it tells you)
Old 09-10-11, 07:24 PM
joe diego
joe diego's Avatar
Awesome thanks!
Old 09-13-11, 05:28 PM
PoGikoSc4
PoGikoSc4's Avatar
Good thing i saw this thread. ive been wondering if my AC comp is bad or just out of juice. Hey Joe can u tell me where is the low side service port pls? ive searched and cant find a dang thing about this. thanks
Old 09-13-11, 05:39 PM
1J0Z SC
1J0Z SC's Avatar
Im jealous, I need AC in my car
Old 09-14-11, 06:24 AM
Justin727
Justin727's Avatar
Did you vacuum down the system correctly?
Old 09-14-11, 06:33 AM
sc300bigtx
sc300bigtx's Avatar
R12 charge
but use a ac machine to vacuum out moisture and any remaining old re-refrigerant
i just recently hooked mine back up finally( 100 degree texas heat sucks ***) and i used just about 1.75 lbs excatly after recovering everything out
Old 09-14-11, 08:05 PM
meangreen1
meangreen1's Avatar
Good info here thanks
Old 09-14-11, 09:13 PM
joe diego
joe diego's Avatar
I didn't vacume out the system. When I dId the swap I unbolted the AC lines then BOOM! Green blast of juice came flowing out of the line.
Anyway, I've been using my AC everyday since I put in the r134. So far so good. Stinks like sheitt for the first few minutes though.
Old 09-15-11, 01:04 AM
speed6
speed6's Avatar
when i swapped mine, i just layed the ac compressor to the side, then bolted it back up. when i added electric fans, it made 1000% difference. I ride with penguins now. People complain its too cold when it's 110 out.
as for the smell, they make a ac flush kit (get it at your local auto value/ bumper to bumper store). it goes in your evap tube and kills all the bacteria in there. It also has a ac refresher to spray through your intake, since we dont have replaceable cabin air filters.
Old 09-15-11, 05:31 AM
joe diego
joe diego's Avatar
Electrical fans will alow it blow colder air? I hope this is true because I have elec. e-bay fans.
I'll flush the whole AC system and take care of the smell when I do a major engine overhaul.
Quick Reply: My 1jz has AC!
