Speedo & RPM not working sc400
so it still not working after the cluster has been rebuilt, I noticed that the N light does not turn on, same for the shifter area. Anyone have any ideas what that is?
bump, so here are the things I found that are not working... I haven't tested the cruise control yet but I will
Speedometer
Odometer
Tachometer
Neutral Light in Cluster
Neutral Light in Shifter
Speedometer
Odometer
Tachometer
so I have confirmed that cruise control also doesn't work.
I have looked at the diagram and also the alldatadiagram. Signal from the source system goes to the tacho and speedo. There is a 10A fuse there which is fine (tested).
Basically
From
Power Source System > 10A GAUGE > Tacho
Power Source System > 10A GAUGE > VSS > Speedo / Trip Meter
A/T Indicator SW > Neutral
haven't looked at cruise yet, all of those are connected to the harness that goes to the ignitor and transmission vss.
Also, can a loose battery connection cause all this?
Basically
From
just to answer the thread, finally found the answer...the harness behind the engine was stretched some how and we just replaced it with a new harness.
PapaCap
SC400 / 300 Classifieds
05-08-14 08:00 AM
