92 SC300 Speedometer/Odometer/Window Issue, PLEASE HELP!!!
Thanks everyone for coming here to help me. I just bought a 92 SC300 for $2400 but with issues.
1.) My speedometer is not working, like needle light is fading.
2.) My odometer is not working.
3.) My passenger side window doesn't work. Passenger window panel doesn't work. I tried to press down and up on the driver panel to see if the passenger side window will work. No luck.
Can anyone please please give me advise on what might be going wrong and what I should do,as well as costs too! Thank you so so much in advance!!!
Speedo needle light fading is a common problem. Window regulators going bad is also a common issue. Also, not to sound ignorant, but make sure your window lock button is not pushed haha. Check out the FAQ thread, some of these issues will be addressed there.
For your window issue first check the window lock switch on the driver side window switch. If that is switch isn't the issue try the window switch on the drivers side. If the window works then replace passenger side switch. Also can you hear the motor working and binding or your not getting any respond at all?
First of all THANK YOU SO MUCH GUYS for responding and helping me out.!!
I made sure the passenger window button on the drivers side lock was off, and I tried pressing the passenger window button on the drivers side, but no response
. .what should I do?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
