Tweak'd Performance 2JZ-GTE SC300 Engine swap
Old 09-21-11, 09:54 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Keeping it clean and simple. I am subscribed!
Old 09-22-11, 06:39 AM
TweakTech
TweakTech's Avatar
Taking the GE out, and cleaning up the engine bay. Took a few cans of degreaser to the engine bay, and the W58 trans.
Before pressure washing
After a good cleaning
Old 09-22-11, 07:42 AM
kez
kez's Avatar
swap looks good guys GL
Old 09-24-11, 01:44 PM
TougeSC3
TougeSC3's Avatar
Looking good Doc. I haven't gotten to see one of your harnesses in an SC. I did see the one you did for my buddies 1JZ'd MKIII. Quality stuff.
Old 09-26-11, 06:59 AM
TweakTech
TweakTech's Avatar
We used the original GE rear sump oil pan, and modified it so the factory oil return would fit.
resurfaced OE flywheel and Competition Clutch
New bearing that came with the clutch kit
Old 09-26-11, 07:02 AM
TweakTech
TweakTech's Avatar
All ready to be dropped in!
We never opened the A/C system. This is the original GE A/C compressor.
All bolted in!
Old 09-26-11, 09:05 AM
97-SC300
97-SC300's Avatar
great progress, i love threads like this
Old 09-26-11, 09:08 AM
99SC42
99SC42's Avatar
Looking good bro keep them coming i like clean and neat swaps, i am glad i am not the only one!
Old 09-26-11, 10:37 AM
account2x
account2x's Avatar
You should always upgrade to 97-02 mkiv supra engine mounts.
Old 09-26-11, 02:56 PM
TweakTech
TweakTech's Avatar
Both motor mounts and the transmission mount are brand new OEM Lexus mounts....and you might want to check the year range in your last post....just sayin.
Old 09-26-11, 07:09 PM
account2x
account2x's Avatar
I know.
The supra mounts (on the right) is of far superior construction to the sc300 mount
direct swap
2/3rds the cost @ wholesale pricing. 67.52 supra mount v 105.63 sc300 mount
.... and when you do use lexus mounts you are supposed to reuse the heat shield since it's not built in like the supra mounts.
Old 09-26-11, 08:08 PM
nlc
nlc's Avatar
^^^^maybe he means from 96. I have 96 tt mounts installed. Idk now im confused too lol
Old 09-29-11, 05:46 AM
stockhatch
stockhatch's Avatar
What kind of hose is that you used for the drains? It almost looks like heater hose which is not a good idea... I would also run Supra mounts just for the strength they offer over the rubber Lexus mounts, but I would bet those Lexus mounts will greatly reduce NVH.
Old 09-30-11, 11:29 AM
luvmysc400
luvmysc400's Avatar
Nice build, so the w58 bolts right up no with no mods?
Old 10-01-11, 12:01 AM
Vwpride12
Vwpride12's Avatar
That's looks like vibrant reinforced silicone hoses, it's made for temps up to 350. Should be good.
Quick Reply: Tweak'd Performance 2JZ-GTE SC300 Engine swap
