1jz/2jzgte and V6 Truck flywheel/The same?
Other then obvious things like the dowels originating in the wrong spot for the clutch cover, but..
They both have 8 holes, they both are flat (No counter weights on the outside), and they should be around the same diameter.
Does anyone with a Toyota Parts EPC know if they have different P/N's?
6-cylinder camry ECU plugs fit in the Chaser ECU, and the 7mgte Truck guys are using the V6 truck disk. So factory stuff definitely swaps around.
This could be a great resource for all the cheap a$$ guys like myself.
Any insight?
Any insight?
Last time I was doing the same research.... so I went into a parts store hunting.. with the 1jz flywheel part number... and they came up with a 2.5 1990+cambry flywheel. I am, not to sure if it fits because i ended up buying a ebay chromoly lightweight flywheel.
So go ahead an take a 1jz flywheel and put it against the cambry one... meassure it and, count how may teeth does have.
