Walbro on a SC400
Old 09-26-11, 07:25 AM
MooJohn
MooJohn's Avatar
Default Walbro on a SC400
My SC400 came with a Walbro courtesy of the previous owner. I just wanted to be sure that this car doesn't have a problem with FPR overrun like some cars do. If there's a chance I've got jacked fuel pressure at idle I'll switch it back to a stock pump since I don't have any mods that require extra fuel.
Old 09-26-11, 01:32 PM
flip3d
flip3d's Avatar
+1. I have a walbro as well for the same reason.
Old 09-26-11, 02:21 PM
turbodremz
turbodremz's Avatar
You shouldnt have a problem unless you have a faulty FPR. My only advice would be to make sure you have a 12v mod done to prevent any issues in the future.
Old 09-26-11, 09:04 PM
xspsi6
xspsi6's Avatar
I just installed my Walbro 2 days ago and no issues thus far.
Old 09-26-11, 10:18 PM
boosted4.6
boosted4.6's Avatar
turbodremz is right................................12v mod is mando
Old 09-26-11, 11:54 PM
xspsi6
xspsi6's Avatar
Imo that would cause the over run issue as the voltage is lower at idle and low rpm so the pump is not working full on and with the mod that would be running at 100% even at idle lower rpm where that is how the over run issue comes about.
Old 09-27-11, 12:22 AM
turbodremz
turbodremz's Avatar
Negative. Your OEM FPR prevents that. IIRC the 400 is the same as the 300 and will not run or idle properly with the Walbro unit in place the FP ECU not bypassed, mine didnt even start. Not to mention, our cars (except the 99 VVTi SC300 iirc) use a return fuel system.
Both the Walbro and the TT Supra Denso units have been used over and over again on stock SC's both 300 and 400 with the 12v mod, and ZERO issues. Your over thinking the flow rate of the pump, but not thinking about what your stock FPR or fuel system was designed to do. Now if you were using an AFPR and didnt have it set properly, then yes, your going to have some issues. But the stock FPR handles it just fine.
Old 11-14-11, 04:31 PM
SC400TT
SC400TT's Avatar
Walbros are loud as heck...I can't seem to do anything to lower that "Whine" they make...Gonna have to sell them and get me a set of Denso's, I believe...
Ryan
Old 11-14-11, 04:49 PM
IanWatson
IanWatson's Avatar
Ryan
you think a walbro is loud ...try a A1000 aeromotive pump lol , but back on topic you shouldnt have an issue with that pump , but do make sure that your FPR is keeping the right fuel pressure , i found 3 cars so far that had an issue with it including mine
cheers
Old 11-14-11, 08:11 PM
CantSeeMe
CantSeeMe's Avatar
cheers
Its all relative really the Walbro's are definately noticeably louder than stock and that whine is pretty annoying... I tolerate it because I need the extra flow and this is what I went with, but I could see how it would be unnaceptable to people wanting a quiet Lexus-like ride. Unless the OP really needs the extra fuel for some reason, personally I would stick with a stock pump.
Old 11-15-11, 08:02 AM
ihiryu
ihiryu's Avatar
I've had mine in since I've owned the car. It is really loud. I did the 12v mod at the same time, so I can't say if it effected the car or not.
nzepeda
01-14-17 05:28 AM
AceVL
01-05-17 08:54 AM
King700se
SC- 1st Gen (1992-2000)
12-09-14 05:14 PM
SoarerV892
03-30-11 07:31 PM
esco2114
15
02-11-11 02:35 PM
Quick Reply: Walbro on a SC400
