Please help!!! (Really means) Crank pulley bolt missing
Hello CL,
I've recently purchased a 97 SC300. I brought it in for a oil change and check up about 1-1 1/2 week after owning it. Everything checked out and was told car seems to be in great running condition, however the the crank pulley bolt was missing.
I was surprised and shocked and immediately worry set in...because i was driving around with this thing for a week. I've order a new one from toyota ($8), but won't be able to install until this weekend.
Does anyone know if the crank pulley will fly off if i continue to drive it like this for the next few days?
I've searched and only found lots of info on removing/installing. Thank you very much.
The tension and the fact that its been on there for a long time is whats keeping it on.
I wouldn't drive it though, at least go to the hardware store and find something to hold you over till the OEM bolt comes in. Seriously, it cant be more than a few minutes to install and torque down. I wouldn't wait.
Title your thread right next time. "Please Help" makes you sound like a girl who is standing on her toilet avoiding a spider.
Edit... Title fixed.
i would NOT drive the car. even if it doesnt damage the engine from it falling out u have a mass of metal spinning at a few thousand RPM if it doesnt shoot thru your hood, it could rbounce off the ground and hurt a bystander or worse. wait it out till the oem bolt comes in
Yeah, don't drive it. Not only for the fact it might come off (not real likely), but you run the risk of damaging the crankshaft snout, keyway, ends up needing a new crank pulley or worse a new crankshaft. Really messy.
ef9
Performance & Maintenance
07-29-18 05:33 PM
nismo2trd
18
04-06-07 05:42 PM
TMaxxTim
07-12-05 09:46 PM
