SC300 auto to manual swap Q&A
Hello CL, I'm in the process of converting my 1992 auto SC300 to a W58 I bought from a friend and need some advice. First, I know that driftmotion sells a kit for a pedal conversion, has anyone used the kit for the MKIV supra on an SC? Because the kit for the SC is about 150 more so if I can I would rather use the supra one. Second, I think I need the front half of the SC manual driveshaft and reuse the rear half of the auto shaft, can anyone confirm this? Again this is for a W58. Third, I'm planning on swapping ecu's so would I need a manual harness or would it just pnp? Fourth will the auto tranny mount work for the W58 or would I need a manual mount? I'm sure there's more I need to know, Its late and I'm kinda tired, but can anyone please answer ASAP
I had mk4 clutch pedal on my car it works just the SC300 one! no modification require it's PNP.
MK4 brake pedal will not work i tried it and i realise it will never work , just save yourself the hassle and the time get the SC300 parts and be done with run around.
RedPhoenix
Performance & Maintenance
11-01-08 12:59 PM
gripNslip
03-27-05 09:49 PM
