Can Someone Tell Me What this Is Called?
Old 10-10-11, 05:20 PM
Exthultu
Exthultu's Avatar
Default Can Someone Tell Me What this Is Called?
This part recently came off the engine of one of my cars. I'm trying to get a name and/or part number for it and the piece it attaches to. It loosened of the bottom left pulley off my SC300. I don't know if I should replace just this "outer ring" or the entire wheel itself. Anyway here is a picture of what came off...
Old 10-10-11, 05:26 PM
EM Dot
EM Dot's Avatar
thats your crank pulley. you need a new one. mine did the same when the rubber insides wore out completely.
Old 10-10-11, 05:34 PM
Exthultu
Exthultu's Avatar
Crank pulley, figured something along the lines. Will i need a new pulley or just the ring that came off of it?
Old 10-10-11, 05:37 PM
turbodremz
turbodremz's Avatar
you need the crank-shaft pulley (pulley, crank dampener)
Toyota PN: 16407-46020
Old 10-10-11, 05:38 PM
kapetajr
kapetajr's Avatar
You would need a new one, you cant just replace the "ring"
edit:turbodremz beat me to it lol,
Old 10-10-11, 05:42 PM
UR2klose
UR2klose's Avatar
crank pulley / harmonic balancer.. mine did the sametime.. as others said youll need to replace the whole pulley
Old 10-10-11, 05:46 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I just sold my extra one too. GL with replacing it. Get a chain wrench and wrap a old belt around the pulley then place the chain wrench on it. The belt will help not tear up the grooves from the chain wrench. I hope this helps. Use a pry bar if necassary.
Old 10-10-11, 06:23 PM
Exthultu
Exthultu's Avatar
Oh well, was hoping to be a quick fix...thanks anyways guys.
Old 10-10-11, 06:24 PM
Exthultu
Exthultu's Avatar
How much can I get one for? Say on the classifieds?
Old 10-10-11, 06:26 PM
over40driv
over40driv's Avatar
It must be a 3.0 engine thing. Ive never heard of that happening to a 4.0.
Old 10-10-11, 06:31 PM
kapetajr
kapetajr's Avatar
Personally I would say dont risk it by buying used, unless you can find one with really low mileage on it,
Old 10-10-11, 06:32 PM
turbodremz
turbodremz's Avatar
PM Aliga. He will set you up right, hes 100% legit, and ships fast.
Hope this works:
https://www.clublexus.com/forums/members/667-aliga.html
Old 10-10-11, 06:43 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Pulley's, pumps, belts, bearings......... I'll take things I buy new for $100, Alex.
Old 10-10-11, 07:21 PM
nivek5sfe
nivek5sfe's Avatar
this is the truth. i bought one used off of here about a year ago. the thing just fell apart while i was pulling into a gas station a week ago. thank god for roadside service on the insurance for the tow.
driftmotion.com sales them new for $299.99. from what ive heard theyre about 400 from the dealer, dont quote me because i didnt even bother calling.
Old 10-10-11, 07:23 PM
SChema
SChema's Avatar
Don't going with one of those solid "performance" pulleys either. The motor needs the harmonic balancer to keep the motor from tearing itself apart.
Quick Reply: Can Someone Tell Me What this Is Called?
