how to swap 1998 motor to 1995 sc300
hello every one,
I just bought a 1995 SC300, the motor blow out i need to replace it.
I'm thinking to find a way to convert to 1998.
Is that possible to do that? Also, witch motor should i look for, and do i have to replace the transmission ?
Please help me out!
Please help me out!
1JZ Single SC400
Are you wanting to stay wih the 300 or go 400? That s the question you need to ask yourself. I would replace with what is in it. Less of a headache. It can be done, but depends on your check book and time. GL
it's alot of time , wiring and frustration involve not worth it if you ask me .. but to each their own.
just find an non VVTi swap it in and be done with the headache.
1998 SC300 uses the same transmission. Only 1998 SC400 got an updated 5 speed automatic.
For your information it is more difficult to swap in a USDM 2JZ-GE VVT-i engine than a JDM 2JZ-GTE VVT-i engine. Reason being the fuel tank (OBD-II sensors & returnless system) and the Immobilizer chip found inside the computer.
oop sorry about it ! i edited it by mistake ...
check out this thread it's very informative
https://www.clublexus.com/forums/per...pre-98-sc.html
240killer
Performance & Maintenance
19
10-10-05 10:52 PM
1995, 1998, 22, 300, 98, az6swaptosc300, immobilizer, lexus, motor, obd2, sc, sc300, stock, swap, transmission
